Action graph and Pathtracing
The pathtracing progress is impact by the action graph. Only after delete of the Action graph, pathtracing progress as normal?
Resolved: I had the “simulate on play” checked. Uncheck and Pathtracing works.
Just to clarify, the fix it to have that option ON or OFF ?
Would you mind sending me the file please
Hi Richard3d: The default setting is “check”. I had follow a tutorial and unchecked it to view if the graph is working without a key.
