Actiongraph TranslateOp has stopped working since update
Operating System:
Windows
Kit Version:
107
Kit Template:
USD Composer
GPU Hardware:
40 series
GPU Driver:
576.02 studio driver just installed
Main Issue:
Actiongraph XfromOp:Translate stopped working since update to Kit version 107.
I am following the actiongraph tutorial to link a cube and a cone. It worked when I was in 106, but cince upgrading it has stopped working. Thank you in advance
Error Code:
2025-05-18 15:00:58 [Warning] [omni.usd] Warning: in SdfPath at line 144 of C:\g\155338243\USD\pxr\usd\sdf\path.cpp – Ill-formed SdfPath <>: :1:0(0): parse error matching struct pxrInternal_v0_24__pxrReserved__::Sdf_PathParser::Path
2025-05-18 15:01:12 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:01:15 [Warning] [omni.graph.tools._impl.deprecate] Use OmniGraphWidget.get_prim_drop_menu_items2 instead.
2025-05-18 15:01:15 [Warning] [omni.graph.tools._impl.deprecate] File “c:/users/dunca/kit-app-template/_build/windows-x86_64/release/extscache/omni.graph.window.core-2.0.0+107.0.3/omni/graph/window/core/graph_widget.py”, line 1270, in on_drop
2025-05-18 15:01:15 [Warning] [omni.graph.tools._impl.deprecate] self.choose_prim_node_dialog(prim_paths, graph_path, canvas_pos, screen_pos)
2025-05-18 15:01:15 [Warning] [omni.graph.tools._impl.deprecate] File “c:/users/dunca/kit-app-template/_build/windows-x86_64/release/extscache/omni.graph.window.core-2.0.0+107.0.3/omni/graph/window/core/graph_widget.py”, line 754, in choose_prim_node_dialog
2025-05-18 15:01:15 [Warning] [omni.graph.tools._impl.deprecate] n_entries = len([e for e in self.get_prim_drop_menu_items() if e[3](graph_path, prim_paths[0])])
2025-05-18 15:01:15 [Warning] [omni.graph.tools._impl.deprecate] File “c:/users/dunca/kit-app-template/_build/windows-x86_64/release/extscache/omni.graph.window.core-2.0.0+107.0.3/omni/graph/window/core/graph_widget.py”, line 1180, in get_prim_drop_menu_items
2025-05-18 15:01:15 [Warning] [omni.graph.tools._impl.deprecate] ogt.DeprecateMessage.deprecated(“Use OmniGraphWidget.get_prim_drop_menu_items2 instead.”)
2025-05-18 15:01:17 [Warning] [omni.fabric.plugin] Warning: attribute inputs:prim not found for path /World/ActionGraph/CubeReadAttrib
2025-05-18 15:01:19 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/CubeReadAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:01:26 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/CubeReadAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:01:26 [Warning] [omni.fabric.plugin] Warning: attribute points not found for bucket id 20
2025-05-18 15:01:40 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/ConeWriteAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:01:45 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/ConeWriteAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:01:52 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/ConeWriteAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:04 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/constant_point3d is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:07 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/constant_point3d is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:09 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/CubeReadAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:10 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/constant_point3d is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:21 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/on_tick is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:22 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/ConeWriteAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:23 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/CubeReadAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:26 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/add is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:26 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/constant_point3d is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:27 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/CubeReadAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:30 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/constant_point3d is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:33 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/add is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:35 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/on_tick is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:38 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/constant_point3d is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:42 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/CubeReadAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:48 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/on_tick is not a <class ‘pxr.UsdGeom.Xformable’>.
2025-05-18 15:02:54 [Warning] [omni.tools.pivot.pivot_tool_core] /World/ActionGraph/ConeWriteAttrib is not a <class ‘pxr.UsdGeom.Xformable’>.
Hi there and thanks for the post. I am sorry to hear this. Maybe in the error code it is giving you the correct instructions. That maybe be depreciated and you have to use something else instead. I can check on this as well.
Also in Kit 107, make sure you go to your extension manager and you install all of the actiongraph bundle and tools.
Thanks Richard. If you can find something that would be great. All the extensions are installed and active.
I am trying to get a sound to play when a door closes. I thought of doing this by reading the orientation or position of a door prim but that’s where I hit this problem. I then thought I could do it on a key press, but the sound, which is only 0.3 seconds long, won’t play if there is a gap between presses of more than 3 seconds. So I press and no play I press multiple times and I get multiple sounds. Confused and frustrated but I’m sure we’ll get there.
I think you would want the sound to be automatic to the door, surely. You don’t want to have to press a key, just to manually play a sound right?
Yes, automatic to the position of the door would be ideal. Thanks.
The door action is currently being triggered by a keypress so the keypress was an idea for a temporary workaround. I would also like to learn how to use the controllers in VR to trigger the door opening of the door when selecting the door handle. I was going to put that in another post. Really appreciate you getting back to me.
