I was working with an AGX orin when the machine shut down and would not boot. The BIOS flash screen will not display at all. I checked using the SDK tools and found that my computer did not detect it correctly. I have used the same laptop to format and install firmware on multiple Orins. I asked for an RMA in the chat, but they told me to post the issue here.
Have you put the board into recovery mode before running SDKM? Or you don’t know what I am talkig about?
Yes I did that by holding the middle button.
Sounds not fully correct.
Ensure the power adapter plugged into the wall socket and the Jetson Developer Kit.
Power up by toggling power button.
(The power button is the left most one of 3 buttons.) -
Place the Jetson Developer Kit into force recovery mode as follows:
- Press and hold the force recovery button.
(The force recovery button is the middle one of 3 buttons.)
Toggle reset button.
(The reset button is the right most one of 3 buttons.) -
Wait two seconds and release the force recovery button.
