您好!请问下,AGX Thor 开发套件中的QSFP28 有指定的光模块推荐吗?如何使用?可直连任意品牌100G光模块使用吗?还是需特定模组?谢谢。
The Jetson Orin Nano is a series of modules developed by NVIDIA, designed for edge AI and robotics applications. There are several modules within this series, each with different specifications and features.
Modules:
- Jetson Orin Nano 4GB-DRAM (P3767-0004): This module has 4GB of DRAM and is in production. It is supported by the Jetson Orin Nano reference carrier board (P3768-0000) and can be flashed using the
jetson-orin-nano-devkitorjetson-orin-nano-devkit-superconfiguration. It supports QSPI-NOR and USB/NVMe drive flashing. - Jetson Orin Nano 8GB-DRAM (P3767-0005): This module has 8GB of DRAM and is in development. It is also supported by the Jetson Orin Nano reference carrier board (P3768-0000) and can be flashed using the
jetson-orin-nano-devkitorjetson-orin-nano-devkit-superconfiguration. It supports QSPI-NOR and microSD Card/USB/NVMe drive flashing. - Jetson Orin Nano 8GB-DRAM (P3767-0003): This module has 8GB of DRAM and is in production. It is supported by the Jetson Orin Nano reference carrier board (P3768-0000) and can be flashed using the
Comparison:
All three modules have similar features and specifications, with the main difference being the amount of DRAM and the production status. The Jetson Orin Nano 4GB-DRAM (P3767-0004) and Jetson Orin Nano 8GB-DRAM (P3767-0003) are in production, while the Jetson Orin Nano 8GB-DRAM (P3767-0005) is in development.
Carrier Board:
The Jetson Orin Nano modules are supported by the Jetson Orin Nano reference carrier board (P3768-0000). This carrier board provides a range of features and interfaces, including M.2 Key E and Key M sockets, an optional RTC battery connector, and more.
Flashing:
The modules can be flashed using the jetson-orin-nano-devkit or jetson-orin-nano-devkit-super configuration. The flashing process supports QSPI-NOR and USB/NVMe drive flashing, as well as microSD Card/USB/NVMe drive flashing for the Jetson Orin Nano 8GB-DRAM (P3767-0005) module.
Power and Performance Management:
The Jetson Orin Nano modules provide a range of power and performance management features, including power management, thermal management, and electrical management. These features are designed to deliver the best user experience possible given the constraints of a particular platform.
Software Support:
The Jetson Orin Nano modules are supported by the NVIDIA Jetson Linux Developer Guide, which provides detailed information on the modules’ features, configurations, and software support.
麻烦帮解答下,谢谢
You could try PB_MMA1B00-C100D_100GbE_QSFP28_MMF_Transceiver.pdf
您好!请问下,开发套件这个接口可以插入100G光模组,与另一网卡的40G光模组通讯吗?或者两端都使用40G光模组互相通讯?谢谢。
Please check the specifications for the Optical modules you plan to use for compatibility. MMA1B00-C100D 100GbE QSFP28 MMF SR4 Transceiver Product Specifications - NVIDIA Docs
