AGX Xavier boot failed
We have a new AGX Xavier and it failed to boot up (see attached) after it was flashed to L4T R32.2.1.
Both SDKmanager(JP4.2.2) and manaully flash AGX by following quickstart quide got same failed boot issue.
The thing is it worked well with L4T R32.2 & R31.1.
Attached the download files scheenshot.
Thank you for any suggestion,
Update
L4T R32.2
SDKmanager (Jetpack4.2.1) flash – boot ok
manaully flash – boot fail
L4t R32.1
manaully flash – boot ok
Hi HuiW,
Could you try remove below folder and run sdkmanager to download again?
$ sudo rm -R /home/<username>/nvidia/nvidia_sdk/JetPack-4.2.2_Linux_P2888
Hi carolyuu,
Thank you for your support.
Yes. It works.
After removed it, both SDKmanager(JP4.2.2) and manually flash AGX worked well.
Thanks,
