2023-11-02 16:53:50 [8,809ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/envs/env_0/Robot/left_finger_tac_1_1
This error occurs when I add a contact sensor to an xform, which causes the robot arm to move randomly in the environment.
Is the xform that the sensor is attached to a rigid body? The current version of the contact sensor requires the immediate parent to be a rigid body to function. However, in the upcoming bugfix, we will allow the rigid body parent to be anywhere above the sensor in the stage tree.
