pekka3
April 4, 2025, 1:12pm
1
Hello!
Please see this video:
First I use Composer 2023.2.5
You can see the Path-Traced optimized USD from IClone8 works great.
Its a max sub-d level with 4K textures so its heavy but it works.
Then on the video I install the latest Kit 107 - today is 4th May.
Now the characters facial blend-shapes are not running, and the body animation is also missing. I cannot even see the skeleton.
What am I missing?
Booted the app with that -d
Also I know the blend-shapes option needs a re-start but It was on already ( from the previous installation, it remembered this. )
Please help me to solve this? I can share the collected scene as PM.
Pekka
You do not need the ā-dā with Kit 107. That is retired.
The new kit app template comes with nothing turned on. Bare bones. You will have to turn on whatever extensions you need in Extension Manager. Just break the scene down, piece by piece and see what is actually broken.
If you want to PM me the scene I can take a look. You would be much better off using our new RTPT / Realtime 2.0
pekka3
April 9, 2025, 9:30am
3
Thank you Richard!
I shall send the file as PM for you.
Here you can see the basic difference of Composer / it 107.
The strange this is that it worked on GTC week when I installed it by following you Kit installation video, but after that the Kit has been updated!
pekka3
April 9, 2025, 9:45am
4
@Richard3D we got it running ok with Linghao Li / Digital Human Tech /
pekka3
April 11, 2025, 7:42am
5
So, on Kit 106 all the animations are visible with these extensions.
I have now activated each and every one of those same extensions on Kit 107.
Here they are in same order:
Still no facial or body movements.
Is there anything else I can do for you to help solve this issue?
Pekka
We will investigate this and see what we can find out.
