Blendshapes not working in Kit 109 and 110
Operating System:
Windows
Linux
Kit Version:
110 (Kit App Template)
109 (Kit App Template)
108 (Kit App Template)
107 (Kit App Template)
106 (Kit App Template)
105 (Launcher)
Kit Template:
USD Composer
USD Explorer
USD Viewer
Custom
GPU Hardware:
A series (Blackwell)
A series (ADA)
A series
50 series
40 series
30 series
GPU Driver:
Latest
Recommended (573.xx)
Other
Work Flow: I have a .usd file with blendhapes animation, verified in Blender. I’d like to use it in Kit. Main Issue: The blendshapes appear in the Stage, and the binding appears to be intact in the properties panels, however the animation isn’t playing in the viewport.
Reproduction Steps:
Error Code:
The blendshapes are there in the stage
and I’ve tried “Enable Blendshapes” on and off, no difference.
PrimaryColorCharatersBP_v01_Scene_1_23_0_face.zip (1.3 MB)
Here’s the usd file.
After looking at your scene, we were able to isolate the issue and already developed a solution for it. This will be released in a future version of kit. We try to make it happen as soon as possible.
Thank you for your contribution and repro scene, it really is appreciated.
@Rafi_FS Can you confirm that your file works fine in Kit 108? Sorry about the inconvenience.
In the new version of kit, with the fix coming, we actually will be removing the old “Enable Blendshapes” option in favor of the new FSD options, which will be enabled by default.
Hey @Rafi_FS
Sorry about the inconvenience. From kit 109 we have a new path and UI for enable Blendshape.
Could you enable the settings in the attached picture and the reload your stage to see if blendshape worked.
If you met a crash, @aschober has a fix on it and it will be released on a future kit.
Thank you.
