Can someone guide me how i export blenderShape generation with blendshape template 52ARkit poses in headless
Hi, myself Shravan.
in audio2Face
I want to export the “blendShap_usdSkel.usd” file, which is generated during blendshape generation inside the Character Transfer tab. My USD file contains all the necessary information, such as skin mesh fitting, skin meshes, etc. However, I need to export this file in headless mode using a script or api if possible.
I have checked the documentation, but there is no information available on this. If there is a way to achieve this through a script, please provide detailed instructions on how to run it.
Please note, I am not referring to the blendshape and joint conversion that are part of the A2F data conversion. tab.
and my next step after getting skel.usd file i want to use file in blend shape and join so i can export in json format through headless mode my requirement is not depend on ui so please help me.
Looking forward to your response.
please someone guide me on above issue which i am facing right now.
I am also facing the same issue. Any help would be appreciated.
Thank You.
@Richard3D @WendyGram @yseol
please check above issue and help me.
A2F
We’ve Moved NVIDIA A2F Support! We have new places to better help you get the support you need.
  1. Developers can submit tickets through the NVIDIA AI Enterprise program NVIDIA Enterprise Customer Support
  2. Developers can discuss ACE through our NVIDIA Developer Discord Server NVIDIA Developer (no GeForce)
