Do you have recommendation what I should try to do next?
Everything else seems to function, but export of blendshape wighs or skeletal animation fails to start. Log text is here.
Traceback (most recent call last):\n File "d:\program files\omniverse\library\audio2face-2021.3.3\exts\omni.audio2face.tool\omni\audio2face\tool\scripts\utils.py", line 30, in wrapper\n return await func(*args, **kwargs)\n File "d:\program files\omniverse\library\audio2face-2021.3.3\exts\omni.audio2face.tool\omni\audio2face\tool\scripts\exporter.py", line 1129, in _run_export_blendshape_weights_json_async\n animationPath = skeletonPrim.GetRelationship("skel:animationSource").GetTargets()[0]\nIndexError: list index out of range\n"}}
{“specversion”:“1.0”,“id”:“4762fa8b-ab52-4e9e-6657-03e9f2989cf1”,“type”:“omni.kit.logging.message”,“source”:“CUT,“data”:{“level”:“error”,“fileName”:“d:\program files\omniverse\library\audio2face-2021.3.3\exts\omni.audio2face.tool\omni\audio2face\tool\scripts\utils.py”,“functionName”:“log_error”,“lineNumber”:19,“threadId”:6528,“processId”:11684,“timestamp”:5456714710200,“message”:”[omni.audio2face.tool] Exception when async ‘<function Exporter._run_export_blendshape_weights_json_async at 0x000001587F7C2D38>’"}}
{“specversion”:“1.0”,“id”:“4762fa8c-ab52-4e9e-6657-03e9f2989cf1”,“type”:“omni.kit.logging.message”,“source”:CUT
I am using Windows 10, A2F 3.3, and the model is standard Character Creator CC3+, using the latest USD plugin, exported with A2F support.
Best regards,
Risto
ps. I have now tried it with two separate PC:s, taking separate steps. The other experiment (Windows 11) yielded similar failyre in exactly the same spot. Is this caused by my iClone CC3+ character?
