After following the guide to setup nvidia deb repo and installing ros-humble-desktop-full, when I try to install isaac-ros-visual-slam using sudo apt install ros-humble-isaac-ros-visual-slam
I get
The following packages have unmet dependencies:
ros-humble-isaac-ros-visual-slam : Depends: ros-humble-isaac-ros-nitros but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
and when I try to run sudo apt install ros-humble-isaac-ros-nitros
I get:
ros-humble-isaac-ros-nitros : Depends: ros-humble-negotiated but it is not installable
and on running sudo apt install ros-humble-negotiated
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package ros-humble-negotiated is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ros-humble-negotiated' has no installation candidate
running rosdep update
or sudo apt update
doesn’t help either.
what can i do here to get isaac ros visual slam to work on jetson’s OS without docker?
System info:
$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
jetson orin nano, 8GB, devkit
