Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Can we get some information regarding the memory layout of RAW12 camera images? I found a related discussion, but it was about a different sensor: AR0231 GMSL Camera RAW format memory layout
Based on our testing, every pixel value (RAW12) is saved in 16bits, and 4 LSBs seem to be replicas of 4 MSBs for padding purpose. Is this correct? Thanks!
Yes, your understanding is correct. In RAW12 images, each pixel value is stored in 16 bits, and the 4 least significant bits (LSBs) are typically used as padding, replicating the 4 most significant bits (MSBs).
May we know why you need this information or if there’s anything specific you’d like to achieve with the RAW12 camera images?
@VickNV, Thanks! We are experimenting to use the RAW12 images from ICP (without ISP), so we need to figure out how to get accurate value of every pixel.
Thank you for the update! To assist you effectively, could you please share more details on why you need to obtain accurate values for every pixel from the RAW12 images when bypassing the ISP (Image Signal Processor)? Understanding the specific use case or application can help us provide more tailored guidance and support.
With the AR0820 sensor, the image frame from ICP is in RAW12 format by default. Can we modify the sample code to change the format? For example, RAW16?
Yes, camera module development is out of the forum support scope. For this matter, I recommend reaching out to your NVIDIA representative for guidance and support.
