The example image is from the Pose Estimation Data Generation Example, but the same has happend on other occations, mainly when generating data via the GUI. I want to emphasize that these artifacts have only occoured when running the Windows version of Isaac, Linux version seems to be fine. Has someone experienced the same before or maybe has a fix for this problem?
Isaac Sim version: 2022.1.0-release.2
Kit SDK version: 103.1
Client Library version: 1.17.5
OS: Windows 10 Enterprise
Hi there, this is a known windows issue where images that are not of power of 2 are not rendered correctly. Running the script with the --vulkan flag should solve the issue.
