Hi how do we automate ( command line ) the browser login process without starting omniverse launcher?
I also try to automate the starting of farm queue and farm agent without manually clicking thru all of them each time when my machine is rebooted. please help thanks!!
There is no way to login other than from the ui here. I am sorry. It should not ask you ever time to log in.
Thanks for your reply Richard!
May I know how often re-login is needed (configurable?) , and is there any way to maximize or to extend the timeout period so as to minimize user/admin interventions ?
Well the first thing to say is, don’t turn off your machine. Once it is logged it, per windows session it should be logged it for a very long time. I am not sure exactly when it asks.
hmmm… our IT could reboot / restart our machines from time to time due to outage, upgrade, and some other reasons…
Any workaround to maintain the login session even after reboot?
Tokens refresh automatically every hour for up to a week. A reboot should not always disturb that. It will just depend. What is the exact reason for your question ? Is it just a pain to log in ?
My group is providing an internal service for other groups to use within the company. This service consists of several modules which currently are being started manually by us via the Launcher. For services in general, the requirement given is to make them self started or restarted after an outage or reboot upon system startup.
Well technically yes, they should already launch back fine, without login, after an outage or a reboot. You get one hour per token. It would not take that long to reboot a machine.
Thx for the info. Say if an outage is over 1hour, that would mean re-login is needed correct? since token would have been expired by then.
I assume so. I would just try to support it as best as you can. There is very little we can do here to force login
