Dear All,
Is here anyone who successfully use the Auvidea J120 with JetPack 3.2?
In the auvidea webpage there support stopped since January 2018. (https://auvidea.com/firmware/)
Dose anyone know how there work is going?
Best Regards,
Sunggoo.
Dear All,
Best Regards,
Sunggoo.
the firmware support for the J120 and other Auvidea carrier boards was published a few days ago. Please go to auvidea.com/firmware.
Best regards,
Jurgen
Jurgen,
It’s good to see you back! ;-) Were you able to enable the second CANBus interface on J120 (rev.7) with TX2 module?
-albertr
Hi Guys,
I am trying to get this up and running on a TX2i with a J120 and am having issues. After following the instructions and replacing both the kernel dtb and bootloader files, flashing the board with JetPack 3.2.1 I am in fact able to flash it with the USB ports not working. I am using the “auvidea-kernel-J90-J120-v1.6.zip” and the “ChangesTX2J140.tar.gz” files to get the hardware tree correct.
Any reason why this isn’t working. I am following the instruction set and replacing the files according to
your instructions and on boot nothing works no keyboard or mouse will function on the ports.
The b196 version does not work anymore and cuda fails. The B23 version works with no usb ports active. The b39 version works with no USB ports active. I’ve tried all 3 Jetpack version 3.2, 3.2.1, 3.3.
cd ~/Downloads
echo Unpack Auvidea J120 Kernel v1.6
unzip -o auvidea-kernel-J90-J120-v1.6.zip
mkdir -p ~/Downloads/ChangesTX2J140
echo Unpacking the ChangesTX2 Update Files…
echo marsden1 | sudo tar xvpf ChangesTX2J140.tar.gz -C ~/Downloads/ChangesTX2J140
mkdir -p ~/Downloads/TX2_USB2_sample_dtb
echo Unpacking the USB2 Sample DTB Files…
echo marsden1 | sudo tar xvpf TX2_USB2_sample_dtb.tar.gz -C ~/Downloads/TX2_USB2_sample_dtb
echo Backup Kernel Files…
mkdir -p ~/Downloads/Backup/kernel
cp -rf ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/kernel/* ~/Downloads/Backup/kernel
cp ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/p2771-0000.conf.common ~/Downloads/Backup
echo Updating Bootloader Files…
cp -rf ~/Downloads/ChangesTX2J140/tegra186-mb1-bct-pmic-quill-p3310-1000-c0* ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/
echo Updating Kernel Files…
cp -rf ~/Downloads/auvidea-kernel-J90-J120-v1.6/auvidea_TX2_Jetpack/dtb/* ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/kernel/dtb/
cp -rf ~/Downloads/auvidea-kernel-J90-J120-v1.6/auvidea_TX2_Jetpack/packages/* ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/kernel/
cp -rf ~/Downloads/auvidea-kernel-J90-J120-v1.6/auvidea_TX2_Jetpack/p2771-0000.conf.common ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/
cp -rf ~/Downloads/auvidea-kernel-J90-J120-v1.6/auvidea_TX2_Jetpack/Image ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/kernel/
cp -rf ~/Downloads/auvidea-kernel-J90-J120-v1.6/auvidea_TX2_Jetpack/zImage ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/kernel/
#echo Patching DTB Files…
#cp -rf ~/Downloads/TX2_USB2_sample_dtb/* ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/kernel/dtb/
echo Apply Binary Changes to the Filesystem…
cd ~/Downloads/JetPack-L4T-3.2.1-linux-x64_b23/64_TX2/Linux_for_Tegra/
#chmod 700 apply_binaries.sh
echo marsden1 | sudo ./apply_binaries.sh
echo Running JetPack 3.2.1…
#chmod +x JetPack-L4T-3.2.1-linux-x64_b23.run
./JetPack-L4T-3.2.1-linux-x64_b23.run
Monil
