AX210 bluetooth not work
Hi All
We use Jetson Orin (Jetson Linux 35.4.1)for design and use AX210 for WI-FI and Bluetooth
But we met bluetooth fail to work.
Attached log below
AX210BT_dmesg.txt (44.3 KB)
please check
Hi @WayneWWW
Do you means the patch you provide the link on this post can fix the bluetooth issue?
If yes, By the github you provide, only for config change, do you suggest we change config to check again?
