Hello, I am a beginner in the domain and I would well understand the step to do for configuring cameras with a jetson system. I read different topics on the subject but want to be sure.
I get a Jetson Xavier NX developer kit recently with 8GB of RAM.
I read the Xavier NX allows up to 6 CSI cameras with a 2-lanes configuration. The board doesn’t allow using up to 6 but it is not the topic.
My questions are :
- When it comes to change the configuration of the Jetson module, to switch from 4-lanes configuration to 2-lanes configuration, do I need to edit the device-tree ?
- Is it possible to read/edit the device-tree file on the jetson directly or only before flash ? (I read this doc)
- I can see different camera sensors on the market and some specifies that it uses 2-lanes and other 4-lanes. What would happen if I use one with its sensor driver configured for 4-lanes use, with a 2-lanes configuration ?
- If I really need to use only 2-lanes configuration, shoud I modify the sensor driver (designed for 4-lanes configuration) or there is another solution ?
- I saw custom boards using different connectors than the usual for CSI (like I-PEX), it allows people to use more than 22pins to get some camera information for instance, how is it possible ? Does the manufacturer has identified the pins and edited the device-tree for this specific connector ?
Thank you for help
