Black screen for a few seconds after exiting fullscreen
Im not sure where to go with this issue. Or what is causing it, but I think its either KDE or an Nvidia problem. The problem started around Christmas, when VRR and new drivers and all that came out. I saw another user also had this issue around that time in discord chat for CachyOs.
I have an Nvidia RTX 4090, and 2x 4k screens.
The monitor im using is an PG42UQ, and it`s 120hz by default. It supports an OC that makes the screen go up to 138hz.
When I activate the 138hz, all fullscreen aplications makes the screen turn black for 2-4 seconds after exiting fullscreen. Then it comes back again. Like if I close youtube in fullscreen is an example to it. This is to everything that has an fullscreen.
This issue is not there, if I put my screen on 120hz automatic adaptive sync.
I tested 2 browsers, Brave and Firefox. Same issue on both.
But if I turn off adaptive sync to never on 138hz, the black screen goes away.
If I swap between 120hz and 138hz, my system hard crashes, so I need to push the reset button and reboot.
For me, its like it struggle to detect my hz in a way. After swapping to 120hz, it also detect my screen as an ultrawide, so i need to change it too 16:9.
Been so many major update past months, that I cant pinpoint what is causing the issue.
Had a new hard crash. So tried logging that as well under the nvidia-bug.report1.log.gz
nvidia-bug-report.log.gz (1.4 MB)
nvidia-bug-report1.log.gz (827.6 KB)
I see more people struggle with this for some reason now in the community. I linked my post and some people comming forward with the same issues.
links to discord posts and nvidia-bug-report.log.gz would definitely increase chances of someone ever looking into this ;-) Cheers!
That 2-4 second blackout when exiting fullscreen on the PG42UQ (especially at 138Hz OC) is almost certainly a DSC (Display Stream Compression) handshake or a mode switch resync.
Since you are pushing 4K at 138Hz, the bandwidth requirement forces the GPU to use DSC. When you exit a fullscreen video (like YouTube), the browser or the compositor (KDE) might be flipping from a “Direct Scanout” mode back to the desktop composition mode. If there is even a slight mismatch in the refresh rate or color depth (e.g., 10-bit vs 8-bit) between the full-screen content and the desktop, the monitor has to drop the signal and handshake again.
To isolate if this is a video codec issue or a pure display signal issue, try this:
  1. Open a static, lightweight page like blacktestscreen.com or just a blank browser tab.
  2. Toggle fullscreen (F11) repeatedly.
If you still get the 2-4 second black screen on a static page, then it is 100% the monitor renegotiating the signal (likely VRR or DSC re-engaging). If it only happens with video content (YouTube/Twitch), then it is likely Firefox/Brave hardware acceleration conflicting with the Nvidia driver’s “Video Color Settings” or G-Sync windowed mode.
For now, sticking to 120Hz (native) usually avoids the DSC handshake delay on that specific Asus panel, as the bandwidth is lower.
I’m on OpenSUSE Leap 16 and I was able to fix this problem on my 160Hz monitor without going down to 120Hz by going into the KDE Display Configuration and turning off Adaptive Sync.
