This was the sequence I followed to update the Nvidia drivers (previously NVIDIA-SMI 430.40 Driver Version: 430.40 CUDA Version: 10.1) on my REMOTE Ubuntu 18.04 workstation:
sudo apt-get purge nvidia*
sudo apt-get autoremove
sudo add-apt-repository ppa:graphics-drivers
sudo apt-get update
sudo ubuntu-drivers --gpgpu nvidia install
When I log in with TeamViewer, the screen is completely black.
Did I do anything wrong? How do I fix this?
I can ssh into the machine and nvidia-smi shows the following:
$ nvidia-smi
Fri Nov 17 01:46:05 2023
±----------------------------------------------------------------------------+ | NVIDIA-SMI 470.223.02 Driver Version: 470.223.02 CUDA Version: 11.4 | |-------------------------------±---------------------±---------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 NVIDIA GeForce ⦠Off | 00000000:0A:00.0 Off | N/A | | 30% 33C P8 21W / 250W | 25MiB / 11019MiB | 0% Default | | | | N/A | ±------------------------------±---------------------±---------------------+ | 1 NVIDIA GeForce ⦠Off | 00000000:41:00.0 On | N/A | | 33% 54C P0 70W / 250W | 55MiB / 11018MiB | 0% Default | | | | N/A | ±------------------------------±---------------------±---------------------+
±----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 3353 G /usr/lib/xorg/Xorg 16MiB | | 0 N/A N/A 5414 G /usr/bin/gnome-shell 6MiB | | 1 N/A N/A 3353 G /usr/lib/xorg/Xorg 53MiB | ±----------------------------------------------------------------------------+
$ lsmod | grep nvidia
nvidia_uvm 1015808 0 nvidia_drm 57344 6 nvidia_modeset 1196032 5 nvidia_drm nvidia 35446784 274 nvidia_uvm,nvidia_modeset drm_kms_helper 172032 1 nvidia_drm drm 401408 10 drm_kms_helper,nvidia,nvidia_drm
Any ideas whatās going on? Thank you!
