Hello!
I’m trying to publish depth images from two cameras. One of the two viewports is black, the second shows a normal image. The viewport that is loaded second is always black and passes zeros to ros2.
Isaac Sim running in container. Screenshot from 2023-09-20 18-14-50.pdf (2.3 MB)
Hi @555kd,
Could you try re-running your setup in the latest the release IsaacSim 2023.1.0 to see if the issue is now resolved?
Thank you. Now all work fine
