Boot up failed after programming image
I am trying to bring up Orin on my PCB board.
After programming the image, the system would stop because of ISP power.
The UART log is attached on for your references and can you give me some suggestions to solve this issue?
programming_orin_failed_20230629.log (56.6 KB)
Hi frank_cf_weng,
Are you designing the custom carrier board for AGX Orin?
ERROR: camera-ip/isp5/isp5.c:1977 [isp5_pm_init] "ERROR: Failed to turn isp power on"
BUG: core/init/init.c:85 [init_all] "*** FIRMWARE INIT FAILED AT LEVEL 95 ***"
Please refer to the following thread to check if it could help to isp power issue.
ISP power on issue cause Orin boot failed - #12 by Bibek
Hi Kevin,
Thanks for your suggestion but one error occurs after modify the config.
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0134 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0135 ] Assuming zero filled SBK key
[ 0.0093 ] Parsing partition layout
[ 0.0106 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0146 ] Change tegra234-bpmp-3701-0004-3737-0000.dtb to tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb
[ 0.0308 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb tegra234-bpmp-3701-0004-3737-0000_with_odm_tmp.dtb
Error: Unexpected error in updating: tegra234-p3701-0004-p3737-0000_with_odm.dtb “Unexpected error in updating: tegra234-p3701-0004-p3737-0000_with_odm.dtb Invalid name ‘“gbe-uphy-config-0’”
Failed flashing t186ref.
Hi Kevin,
Sorry that the error is caused by my editing faults.
After I correct the wrong modification, everything is good.
Thanks for your support and you can close this ticket.
