Hi @linuxdev,
Agreed!
Thanks for the reply! I noticed it was a faulty micro-B USB cable. I couldn’t find the original one from devkit but I found an original micro-B USB cable. For the connection via USB, it works, it now shows “Nvidia Corp.” after “lsusb -d 0955:7c18”.
I am not using VM, I am using a host Dell laptop on Ubuntu 18.04. I have seen two ways to put Jetson TX2 on recovery mode: 1) following instructions as per SDKManager, turning ON the Jetson TX2, pressing the forced recovery button, pressing the reset button, while the forced recovery button is already pressed and after 2 secs releasing the button; 2) power ON the jetson, while the forced recovery button is already pressed and then press reset and release the forced recovery button. Don’t know which one is correct, I tried both, but now it has a new problem after it starts flashing for about 5-10%.
Following is the terminal log, if you can suggest what’s wrong. It says “lost connection”, but how? There is nothing to hinder the connection. Not sure if Ethernet should be connected or not. I had tried it with Ethernet port connected to a W-LAN router.
• 09:29:12 INFO : *** Retrying to install. attempt number: 3
• 09:29:12 INFO : CUDA on Host : download 'CUDA on Host' success
• 09:29:12 INFO : Drivers for Jetson TX2 & TX2i : download 'Drivers for Jetson TX2 & TX2i' success
• 09:29:12 INFO : OpenCV on Host : download 'OpenCV on Host' success
• 09:29:12 INFO : File System and OS : download 'File System and OS' success
• 09:29:12 INFO : NVIDIA Nsight Graphics : download 'NVIDIA Nsight Graphics' success
• 09:29:12 INFO : NVIDIA Nsight Systems : download 'NVIDIA Nsight Systems' success
• 09:29:12 INFO : VisionWorks on Host : download 'VisionWorks on Host' success
• 09:29:12 INFO : DevTools Documentation : download 'DevTools Documentation' success
• 09:29:12 INFO : CUDA Cross Compile Package on Host : download 'CUDA Cross Compile Package on Host' success
• 09:29:12 INFO : install 'CUDA on Host' success
• 09:29:12 INFO : install 'Drivers for Jetson TX2 & TX2i' success
• 09:29:12 INFO : install 'OpenCV on Host' success
• 09:29:12 INFO : install 'File System and OS' success
• 09:29:12 INFO : install 'NVIDIA Nsight Graphics' success
• 09:29:12 INFO : install 'NVIDIA Nsight Systems' success
• 09:29:13 INFO : install 'VisionWorks on Host' success
• 09:29:13 INFO : install 'DevTools Documentation' success
• 09:29:13 INFO : install 'CUDA Cross Compile Package on Host' success
• 09:29:13 INFO : OpenCV on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : OpenCV on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : OpenCV on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : OpenCV on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : cuDNN on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:13 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:14 INFO : cuDNN on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:14 INFO : cuDNN on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:29:14 INFO : VisionWorks on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
• 09:29:14 INFO : VisionWorks on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
• 09:29:14 INFO : VisionWorks on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
• 09:29:14 INFO : Multimedia API : Found file /home/test/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
• 09:29:16 INFO : TensorRT on Target : Found file /home/test/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
• 09:29:16 INFO : CUDA Toolkit for L4T : Found file /home/test/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
• 09:29:16 DEBUG : running command < [ `lsusb | grep -c "NVidia Corp"` -ne 1 ] >
• 09:29:17 ERROR : command terminated with error
• 09:29:17 INFO : 0955:7c18 detected.
• 09:29:17 DEBUG : running command < lsusb | grep 0955:7020 >
• 09:29:17 INFO : Jetson device is in recovery mode.
• 09:29:17 DEBUG : running command < lsusb | grep 0955:7c18 >
• 09:29:17 INFO : Bus 002 Device 010: ID e[01;31me[K0955:7c18e[me[K NVidia Corp.
• 09:29:17 INFO : command finished successfully
• 09:29:17 INFO : Verified, 0955:7c18 detected in recovery mode.
• 09:29:17 INFO : Start to install 'Device Mode Host Setup in Flash'
• 09:29:17 DEBUG : Device Mode Host Setup in Flash : running command < cd '/home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH' -v='1.0' -l='/home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310' -L='/home/test/.nvsdkm/logs/JetPack_4.2_Linux' -p='2628' -t='P3310' -e='undefined' >
• 09:29:17 INFO : Device Mode Host Setup in Flash : [ Disk Avail:70.89 GB ]
• 09:29:17 INFO : Device Mode Host Setup in Flash : Using GenericInstaller to Install NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH
• 09:29:17 INFO : Device Mode Host Setup in Flash : change working directory to /home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310
• 09:29:17 INFO : Device Mode Host Setup in Flash : [ Component Install Started ]
• 09:29:17 INFO : Device Mode Host Setup in Flash : current working directory is /home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310
• 09:29:17 INFO : Device Mode Host Setup in Flash : exec_command [host]:
• 09:29:17 INFO : Device Mode Host Setup in Flash : **********************
• 09:29:17 INFO : Device Mode Host Setup in Flash : #!/bin/bash
• 09:29:17 INFO : Device Mode Host Setup in Flash : set -e
• 09:29:17 INFO : Device Mode Host Setup in Flash : function safe_apt_install {
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo "*begin $1, $2"
• 09:29:17 INFO : Device Mode Host Setup in Flash : tmp_log=/tmp/jetpack_dpkg_log.txt
• 09:29:17 INFO : Device Mode Host Setup in Flash : sudo rm -f $tmp_log
• 09:29:17 INFO : Device Mode Host Setup in Flash : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
• 09:29:17 INFO : Device Mode Host Setup in Flash : while [ ${CMD_STATUS} -ne 0 ]; do
• 09:29:17 INFO : Device Mode Host Setup in Flash : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
• 09:29:17 INFO : Device Mode Host Setup in Flash : else
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo "Unhandled error when running $1"; exit 1
• 09:29:17 INFO : Device Mode Host Setup in Flash : fi
• 09:29:17 INFO : Device Mode Host Setup in Flash : done
• 09:29:17 INFO : Device Mode Host Setup in Flash : }
• 09:29:17 INFO : Device Mode Host Setup in Flash : eth_port_name=$(ip route show default | awk '/default via/ {print $5; exit}')
• 09:29:17 INFO : Device Mode Host Setup in Flash : if [[ $eth_port_name == '' ]]; then
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo 'Can not found route default $eth_port_name, device mode setup failed!'
• 09:29:17 INFO : Device Mode Host Setup in Flash : exit 0
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo 'Found route default' $eth_port_name', setting up device mode'
• 09:29:17 INFO : Device Mode Host Setup in Flash : setup_t='192.168.55.0/24'
• 09:29:17 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
• 09:29:17 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
• 09:29:17 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
• 09:29:17 INFO : Device Mode Host Setup in Flash : sudo sysctl -w net.ipv4.ip_forward=1
• 09:29:17 INFO : Device Mode Host Setup in Flash : check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
• 09:29:17 INFO : Device Mode Host Setup in Flash : if [[ $check_google_dns == *'Got answer'* ]]; then
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo 'Device mode on host successfuly set with DNS 8.8.8.8!'
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo 'Default google DNS is not working, trying to find a valid server in local host settings!'
• 09:29:17 INFO : Device Mode Host Setup in Flash : dns_list=$(nmcli -t device show $eth_port_name | grep 'DNS' | grep -o '[^:]*$')
• 09:29:17 INFO : Device Mode Host Setup in Flash : for dns in $dns_list; do
• 09:29:17 INFO : Device Mode Host Setup in Flash : check_dns=$(dig @$dns nvidia.com || true)
• 09:29:17 INFO : Device Mode Host Setup in Flash : if [[ $check_dns == *'Got answer'* ]]; then
• 09:29:17 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
• 09:29:17 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo 'Device mode on host successfuly set with DNS' $dns'!'
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo 'Can not found a valid DNS server, device mode setup failed!'
• 09:29:17 INFO : Device Mode Host Setup in Flash : echo 'If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.'
• 09:29:17 INFO : Device Mode Host Setup in Flash : exec_command: /tmp/tmp_NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH.sh
• 09:29:17 INFO : Device Mode Host Setup in Flash : Found route default wlp2s0, setting up device mode
• 09:29:17 INFO : Device Mode Host Setup in Flash : net.ipv4.ip_forward = 1
• 09:29:17 INFO : Device Mode Host Setup in Flash : Device mode on host successfuly set with DNS 8.8.8.8!
• 09:29:17 INFO : Device Mode Host Setup in Flash : [ Component Install Finished Successfully ]
• 09:29:17 INFO : Device Mode Host Setup in Flash : [ 8.00 KB used. Disk Avail: 70.89 GB ]
• 09:29:17 INFO : Device Mode Host Setup in Flash : [ NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH Install took 0s ]
• 09:29:17 INFO : Device Mode Host Setup in Flash : command finished successfully
• 09:29:17 INFO : install 'Device Mode Host Setup in Flash' success
• 09:29:17 INFO : Start to install 'Flash Jetson TX2'
• 09:29:17 DEBUG : Flash Jetson TX2 : running command < cd '/home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310' -L='/home/test/.nvsdkm/logs/JetPack_4.2_Linux' -p='2628' -t='P3310' -e='undefined' >
• 09:29:17 INFO : Flash Jetson TX2 : [ Disk Avail:70.89 GB ]
• 09:29:17 INFO : Flash Jetson TX2 : Using GenericInstaller to Install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP
• 09:29:17 INFO : Flash Jetson TX2 : change working directory to /home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310/Linux_for_Tegra
• 09:29:17 INFO : Flash Jetson TX2 : [ Component Install Started ]
• 09:29:17 INFO : Flash Jetson TX2 : current working directory is /home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310/Linux_for_Tegra
• 09:29:17 INFO : Flash Jetson TX2 : exec_command [target]:
• 09:29:17 INFO : Flash Jetson TX2 : **********************
• 09:29:17 INFO : Flash Jetson TX2 : #!/bin/bash
• 09:29:17 INFO : Flash Jetson TX2 : set -e
• 09:29:17 INFO : Flash Jetson TX2 : function safe_apt_install {
• 09:29:17 INFO : Flash Jetson TX2 : echo "*begin $1, $2"
• 09:29:17 INFO : Flash Jetson TX2 : tmp_log=/tmp/jetpack_dpkg_log.txt
• 09:29:17 INFO : Flash Jetson TX2 : sudo rm -f $tmp_log
• 09:29:17 INFO : Flash Jetson TX2 : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
• 09:29:17 INFO : Flash Jetson TX2 : while [ ${CMD_STATUS} -ne 0 ]; do
• 09:29:17 INFO : Flash Jetson TX2 : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
• 09:29:17 INFO : Flash Jetson TX2 : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
• 09:29:17 INFO : Flash Jetson TX2 : else
• 09:29:17 INFO : Flash Jetson TX2 : echo "Unhandled error when running $1"; exit 1
• 09:29:17 INFO : Flash Jetson TX2 : fi
• 09:29:17 INFO : Flash Jetson TX2 : done
• 09:29:17 INFO : Flash Jetson TX2 : }
• 09:29:17 INFO : Flash Jetson TX2 : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
• 09:29:17 INFO : Flash Jetson TX2 : sudo reboot forced-recovery
• 09:29:17 INFO : Flash Jetson TX2 : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh"
• 09:31:28 ERROR : Flash Jetson TX2 : lost connection
• 09:33:39 INFO : Flash Jetson TX2 : exit status 255
• 09:33:39 WARNING : Flash Jetson TX2 : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh" finished with error, but ignored
• 09:33:39 INFO : Flash Jetson TX2 : exec_command: sleep 20
• 09:33:59 INFO : Flash Jetson TX2 : exec_command: sudo ./flash.sh jetson-tx2 mmcblk0p1
• 09:33:59 INFO : Flash Jetson TX2 : ###############################################################################
• 09:33:59 INFO : Flash Jetson TX2 : # L4T BSP Information:
• 09:33:59 INFO : Flash Jetson TX2 : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
• 09:33:59 INFO : Flash Jetson TX2 : # DATE: Wed Mar 13 07:41:08 UTC 2019
• 09:33:59 INFO : Flash Jetson TX2 : # Target Board Information:
• 09:33:59 INFO : Flash Jetson TX2 : # Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
• 09:33:59 INFO : Flash Jetson TX2 : # OpMode: production, Boot Authentication: NS,
• 09:33:59 INFO : Flash Jetson TX2 : ./tegraflash.py --chip 0x18 --applet "/home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
• 09:33:59 ERROR : Flash Jetson TX2 : /usr/bin/env: ‘python’
• 09:33:59 ERROR : Flash Jetson TX2 : : No such file or directory
• 09:33:59 INFO : Flash Jetson TX2 : Reading board information failed.
• 09:33:59 INFO : Flash Jetson TX2 : exit status 1
• 09:33:59 INFO : Flash Jetson TX2 : [ Component Install Finished with Error ]
• 09:33:59 ERROR : Flash Jetson TX2 : NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
• 09:33:59 INFO : Flash Jetson TX2 : [ 0.00 B released. Disk Avail: 70.89 GB ]
• 09:33:59 INFO : Flash Jetson TX2 : [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 4m43s ]
• 09:33:59 INFO : Flash Jetson TX2 : command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
• 09:33:59 ERROR : Flash Jetson TX2 : command terminated with error
• 09:33:59 ERROR : install 'Flash Jetson TX2' failure, command < cd '/home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/test/Dokumente/jetpack4.2/JetPack_4.2_Linux_P3310' -L='/home/test/.nvsdkm/logs/JetPack_4.2_Linux' -p='2628' -t='P3310' -e='undefined' > terminated with error
• 09:33:59 INFO : install 'Device Mode Host Setup in Target SDK' Skipped
• 09:33:59 INFO : install 'DateTime Target Setup' Skipped
• 09:33:59 INFO : install 'CUDA Toolkit for L4T' Skipped
• 09:33:59 INFO : install 'cuDNN on Target' Skipped
• 09:33:59 INFO : install 'TensorRT on Target' Skipped
• 09:33:59 INFO : install 'OpenCV on Target' Skipped
• 09:33:59 INFO : install 'VisionWorks on Target' Skipped
• 09:33:59 INFO : install 'Multimedia API' Skipped
• 09:34:00 INFO : All done!
