Bootburn on the SoC is failing
DRIVE OS Version: Provide DRIVE OS version. Example: 7.0.3
Issue Description:
We are using Nvidia thor hardware, and trying to perform bootburn on the SoC.
for bootburn process we are following steps mentioned by nvidia in the link below
In the Minicom shell we enter into Recovery Mode
tegrarecovery x1 on
tegrareset x1
And then from the Docker terminal we are executing below commands
cd /drive/drive-foundation/tools/flashtools/bootburn
python3 bootburn.py -b p3960-10-sw01 -l -u pct-bin kernel-dtb
but we are facing issue
*ERROR: Failed to create hpse_t264 pkg due to /drive/drive-foundation/security/spvault/out/nvidia/spvault/conf-blob/t26x/spvault-hpse-oem-conf.bin is not found.
We need to know why is this failing and is there any additional things we need perform.?
Complete Logs:
root@7.0.3.0-0010-linux-nsr:/drive/drive-foundation/tools/flashtools/bootburn# python3 bootburn.py -b p3960-10-sw01 -l -u pct-bin kernel-dtb
********* Starting bootburn/bootburn.py *********
Command Line Arguments :: [‘bootburn.py’, ‘-b’, ‘p3960-10-sw01’, ‘-l’, ‘-u’, ‘pct-bin’, ‘kernel-dtb’]
2026-01-20 15:33:02,461 - INFO - Initializing SOC group selector
2026-01-20 15:33:02,462 - INFO - Found SOC group for board p3960-10-sw01
********* Starting t264 bootburn py ********
Bootburn Starting with arguments [‘bootburn.py’, ‘-b’, ‘p3960-10-sw01’, ‘-l’, ‘-u’, ‘pct-bin’, ‘kernel-dtb’]
Default Schema:/drive/drive-foundation/tools/flashtools/bootburn_t264_py/nv-customer-data-schema.json
cwd in setBoardConfigPath :: /drive/drive-foundation/tools/flashtools/bootburn_t264_py
cwd in loadBoardGoldenRegsFile :: /drive/drive-foundation/tools/flashtools/bootburn_t264_py
Check finished successfully
Done parsing command line
[bootburn]: [executeShellCommand(155)] : command = whoami
cwd = /drive/drive-foundation/tools/flashtools/bootburn_t264_py
[bootburn]: [executeShellCommand(162)] : root
[bootburn]: [getListTargetsInRecovery(3570)] : Bus 001 Device 012: ID 0955:7026 NVIDIA Corp. APX
[bootburn]: [getListTargetsInRecovery(3570)] : Bus 001 Device 002: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
p3960-10-sw01
[bootburndie0]: [executeShellCommand(155)] : command = whoami
[bootburndie0]: [executeShellCommand(162)] : root
[bootburndie0]: [GetTargetECID(784)] : Target BR_CID: 0x80012641783DC0C908000000170301C0
[bootburndie0]: [GetTargetECID(785)] : Target ECID: 0x1783DC0C908000000170301C0
[bootburndie0]: [GenAdbSerialNum(551)] : ADB serial number is 2U1TO34GG00000BG60E0
[bootburndie0]: [CheckForDeviceType(882)] : Detected ES production device type
In BoardSetFilePathsAndDefaultValues in targetConfig
n_FlashFirmware is set to True
[bootburndie0]: creating and flashing coldboot images
[bootburndie0]: [Boot_Create_Flash_Coldboot(1439)] : Creating & Flashing images
[bootburndie0]: Creating rcm-flash images
[bootburndie0]: [Boot_Create_Flash_Coldboot(1442)] : flashingCFG :: /drive/drive-foundation/tools/flashtools/flashing_kernel/flashing_configs/t264/quickboot_flashing.cfgself.targetConfig.p_OutDirPath :: /drive/drive-foundation/tools/flashtools/bootburn_t264_py/__temp_t264/die0-13c15cd36cc
/drive/drive-foundation/tools/flashtools/bootburn_t264_py/__temp_t264/die0-13c15cd36cc/rcm-flash/tegrasign_v3_internal.py:1339: SyntaxWarning: invalid escape sequence ‘\d’
m = re.search(‘Key size is (\d+)’, ret_str)
/drive/drive-foundation/tools/flashtools/bootburn_t264_py/__temp_t264/die0-13c15cd36cc/rcm-flash/tegrasign_v3_internal.py:1385: SyntaxWarning: invalid escape sequence ‘\d’
/drive/drive-foundation/tools/flashtools/bootburn_t264_py/_temp_t264/die0-13c15cd36cc/rcm-flash/tegrasign_v3_internal.py:1752: SyntaxWarning: invalid escape sequence ‘\d’
re_string = 'kdf_args
’ + temp_stem + ‘(\d).yaml’
/drive/drive-foundation/tools/flashtools/bootburn_t264_py/__temp_t264/die0-13c15cd36cc/rcm-flash/tegrasign_v3_util.py:158: SyntaxWarning: invalid escape sequence ‘\d’
m = re.search(‘[1]+’, arg)
command line used was:
Exception 8 raised in bootburn_active
File “/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t264_py/bootburn.py”, line 144, in bootburn_active
bootburnThor.Boot_Create_Flash_Coldboot()
File “/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t264_py/bootburn_thor.py”, line 1445, in Boot_Create_Flash_Coldboot
self.CreateVDKImages(flashingCFG, self.targetConfig.p_OutDirPath, “rcm-flash”)
File “/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t264_py/bootburn_thor.py”, line 878, in CreateVDKImages
self.GenerateImage(self.storageCfgParser.cfgFileList, l_Operation, operationPath)
File “/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t264_py/bootburn_lib.py”, line 1919, in GenerateImage
self.GenerateHpseSbPkg(l_Image, p_TempDumpPath, chain)
File “/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t264_py/bootburn_thor.py”, line 631, in GenerateHpseSbPkg
raise AbnormalTermination(“ERROR: Failed to create %s pkg due to %s is not found” %(pkg, f_OespBinAbs),
File “/drive/drive-foundation/tools/flashtools/bootburn/../bootburn_t264_py/flashtools_nverror.py”, line 261, in AbnormalTermination
raise OSError(errorCode)
OSError: 8
  1. \d ↩︎
Dear @swapnil.langarkande ,
Is it like you want to flash DRIVE OS 7.0.3 to target or you wants to flash any customizations ?
Is the board variant p3960-10-sw01?
Could you verify board variant from part number Requirements for Development Environments — NVIDIA DriveOS 7.0 Linux Installation Guide
Hi @SivaRamaKrishnaNV ,
We have started with flashing DRIVE OS 7.0.3 to the target. The board variant we are using is p3960-10-sw03 and the part number is 940-63960-0010-000.
Best Regards,
Shashidhar
Dear @shashidhar.kasoju.pb1 , @swapnil.langarkande ,
May I know if both are working together on same issue?
Is the issue resolved?
Hello @SivaRamaKrishnaNV
Yes myself and @shashidhar.kasoju.pb1 we both work together in a same team and on same issue.
Issue is not yet resolved.
Regards
Swapnil
Dear @swapnil.langarkande @shashidhar.kasoju.pb1 ,
Does normal flashing command work(./bootburn.py -b <board_variant> -x /dev/ttyACM2 when board is in normal mode) ?
Could you please share the used bind and flash commands and logs for p3960-10-sw03?
Is the board in recovery mode or normal mode before running your commands?
@swapnil.langarkande could you please check my private message?
Based on your suggestion in previous message I tried flashing command in normal mode (BOard is in normal mode) Still we are facing issue. I am adding logs below
Logs:
Command Line Arguments :: [‘./bootburn.py’, ‘-b’, ‘p3960-10-sw03’, ‘-x’, ‘/dev/ttyACM2’]
Bootburn Starting with arguments [‘./bootburn.py’, ‘-b’, ‘p3960-10-sw03’, ‘-x’, ‘/dev/ttyACM2’]
[bootburn]: [GetInfoRom(599)] : Read skuinfo from InfoRom…
[bootburn]: Execute command on Aurix serial port
[bootburn]: [ParseInfoRom_Print(673)] : Product Part Number: 670-63960-0010-000
[bootburn]: [getListTargetsInRecovery(3570)] : Bus 001 Device 008: ID 0955:7026 NVIDIA Corp. APX
[bootburn]: [GetTegrasAssocWithAurix(514)] : Setting Tegra-A in recovery…
[bootburn]: [GetTegrasAssocWithAurix(518)] : Done
[bootburn]: [GetTegrasAssocWithAurix(532)] : retrying board recovery check…
[bootburn]: [getListTargetsInRecovery(3570)] : Bus 001 Device 009: ID 0955:7026 NVIDIA Corp. APX
p3960-10-sw03
Platform config path - /drive/drive-foundation/out/p3960-10-sw03/platform_config.json - does not exist
Platform config file not found – not overiding values
[bootburnTegra-A]: [executeShellCommand(155)] : command = whoami
[bootburnTegra-A]: [executeShellCommand(162)] : root
[bootburnTegra-A]: [GetTargetECID(784)] : Target BR_CID: 0x80012641783DE205240000000A028100
[bootburnTegra-A]: [GetTargetECID(785)] : Target ECID: 0x1783DE205240000000A028100
[bootburnTegra-A]: [GenAdbSerialNum(551)] : ADB serial number is 2U1TS82I800000505080
[bootburnTegra-A]: [CheckForDeviceType(882)] : Detected ES production device type
e[01;31mBind partitions does not look to have been run for board p3960-10-sw03
please make bind partitions before running bootburne[0m
e[01;31mException 4 raised in bootburn_active e[0m
This indicates the bind_partitions command did not use p3960-10-sw03 before running bootburn
Could you please provide any update for this topic?
Is the issue resolved? Can we close the topic?
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
