The known problem with:
“Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)”
Seriously, is there any prospect of fixing this bs once and for all?
The only way to use my GPU is to avoid installing CUDA at all.
Clean install, Quadro P4000 on Win 10, cuda_10.1.105_win10_network.exe
You can turn off driver signature checks if you wish. Google for that. It’s not hard to find.
If you don’t want to turn off driver signing checks, then install the latest signed driver for your GPU, and use whatever CUDA version is compatible with that.
When you install CUDA, deselect the option to install the bundled driver. Keep your signed driver.
Currently, the latest Quadro New Feature driver is WHQL-signed for the Quadro P4000, and it is a 419.xx driver which will work with CUDA 10.1 or pretty much any prior version of CUDA that you wish.
[url]https://www.nvidia.com/Download/driverResults.aspx/143117/en-us[/url]
