Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model:
- Driver Version:
Topic Description
Detailed Description
I created a USD scene containing vegetation, to multiply the vegetation programatically I am using Point Instancer. As vegetation assets I am using the Isaac-SIM Library trees.
Now I am adding 3D bounding boxes, but Isaac-SIM crashes every time I activate BoundingBox3D>Show Window.
I have the same problem with both Isaac-SIM2023 and Isaac-SIM4.5
I noticed that this problem occurs when the asset itself also uses PointInstancer to create the branches and leaves in the tree, so it seems to be a problem with nested PointInstancer
Steps to Reproduce
- Take a tree from Isaac-SIM Library (for instance Black_Oak) as Prototype, and then use PointInstancer to add multiple times the tree to the scene
- Enable “BoundingBox3D” and “Show Window”
- Check your console. Isaac-SIM should have crashed by now with code 127
Error Messages
Isaac-SIM2023.1.1
Isaac-SIM4.5:
2025-05-19 09:37:58 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-05-19 09:37:58 [67ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip’ for upload.
2025-05-19 09:37:58 [373ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp’ with 10 retries remaining.
2025-05-19 09:37:58 [378ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.toml’ with 10 retries remaining.
2025-05-19 09:37:58 [396ms] [Error] [carb.crashreporter-breakpad.plugin] ‘crashreport.gui’ exited with code 127
2025-05-19 09:37:58 [402ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip’
2025-05-19 09:37:58 [407ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Uploading minidump: file:‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip’ svr:‘https://services.nvidia.com/submit’
2025-05-19 09:37:58 [412ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata for upload:
2025-05-19 09:37:58 [416ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘BuildGitlabJobID’ = ‘128178599’
2025-05-19 09:37:58 [419ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘CarbSdkVersion’ = ‘180.6+release.7436.c5558fdf.gl’
2025-05-19 09:37:58 [422ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘CrashTime’ = ‘Mon May 19 09:37:58 2025 GMT’
2025-05-19 09:37:58 [425ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘DriverShaderCacheWrapper’ = ‘disabled’
2025-05-19 09:37:58 [429ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘DumpId’ = ‘80041d64-970d-4d5b-5e5ec3b7-f9decbfa’
2025-05-19 09:37:58 [432ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘LastUploadStatus’ = ‘’
2025-05-19 09:37:58 [435ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘ProductName’ = ‘OmniverseKit’
2025-05-19 09:37:58 [439ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘PythonTracebackStatus’ = ‘‘py-spy’ successfully wrote info to ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.py.txt’’
2025-05-19 09:37:58 [443ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘RetryCount’ = ‘0’
2025-05-19 09:37:58 [446ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘StartupTime’ = ‘1747647375’
2025-05-19 09:37:58 [450ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘UploadSuccessful’ = ‘0’
2025-05-19 09:37:58 [453ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘UptimeSeconds’ = ‘103’
2025-05-19 09:37:58 [457ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘UserStory’ = ‘’
2025-05-19 09:37:58 [460ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘UserStoryStatus’ = ‘‘crashreport.gui’ exited with code 127’
2025-05-19 09:37:58 [463ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘Version’ = ‘106.5.0+release.162521.d02c707b.gl’
2025-05-19 09:37:58 [467ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘aftermath_enabled’ = ‘1’
2025-05-19 09:37:58 [470ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘aftermath_flags’ = ‘3’
2025-05-19 09:37:58 [475ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘aftermath_status’ = ‘auto-enabled’
2025-05-19 09:37:58 [479ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘aftermath_version’ = ‘2024.1’
2025-05-19 09:37:58 [482ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘appName’ = ‘Isaac-Sim Full’
2025-05-19 09:37:58 [485ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘appState’ = ‘started’
2025-05-19 09:37:58 [488ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘appVersion’ = ‘4.5.0’
2025-05-19 09:37:58 [491ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘autoloadExts’ = ‘dbs.per.camera_core-1.6.0,dbs.per.camera_ros2-1.6.0,dbs.per.common-1.6.0,dbs.per.isaac.ros2_bridge-1.6.0,omni.anim.timeline-106.4.2,dbs.ipm.fmi-0.0.36-20250128080706-f3cdaaf,dbs.ipm.fmi_ui-1.0.0,dbs.per.isaac.sensor-1.6.0,dbs.ipm.simcontroller-1.0.0,omni.anim.window.timeline-106.4.0,omni.kit.window.movie_capture-2.4.2,dbs.per.camera_psf_utils-1.6.0,omni.anim.widget.timeline-0.1.12’
2025-05-19 09:37:58 [495ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildBranch’ = ‘release’
2025-05-19 09:37:58 [498ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildCi’ = ‘gl’
2025-05-19 09:37:58 [502ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildConfig’ = ‘release’
2025-05-19 09:37:58 [507ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildGitlabJobName’ = ‘kit-build-release-linux-x86_64’
2025-05-19 09:37:58 [511ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildGitlabJobStage’ = ‘kit-build’
2025-05-19 09:37:58 [514ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildGitlabPipelineID’ = ‘21399756’
2025-05-19 09:37:58 [517ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildHash’ = ‘d02c707b’
2025-05-19 09:37:58 [520ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildMajor’ = ‘106’
2025-05-19 09:37:58 [523ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildMinor’ = ‘5’
2025-05-19 09:37:58 [526ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildNumber’ = ‘162521’
2025-05-19 09:37:58 [530ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildPatch’ = ‘0’
2025-05-19 09:37:58 [534ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘buildVersion’ = ‘106.5.0’
2025-05-19 09:37:58 [540ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘carboniteFrameworkVersion’ = ‘180.6+release.7436.c5558fdf.gl’
2025-05-19 09:37:58 [543ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘carboniteSdkVersion’ = ‘180.6+release.7436.c5558fdf.gl’
2025-05-19 09:37:58 [546ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘commandLine’ = ‘/opt/nvidia-omniverse/library/isaac-sim-4.5.0/kit/kit /opt/nvidia-omniverse/library/isaac-sim-4.5.0/apps/isaacsim.exp.full.kit --ext-folder /opt/nvidia-omniverse/library/isaac-sim-4.5.0/apps’
2025-05-19 09:37:58 [549ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘cpuCoreLimited’ = ‘12’
2025-05-19 09:37:58 [552ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘cpuId’ = ‘Intel64 Family 6 Model 106 Stepping 6’
2025-05-19 09:37:58 [555ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘cpuLogicalCoresBareMetal’ = ‘12’
2025-05-19 09:37:58 [558ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘cpuName’ = ‘Intel(R) Xeon(R) Platinum 8362 CPU @ 2.80GHz’
2025-05-19 09:37:58 [562ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘cpuPhysicalCoresBareMetal’ = ‘12’
2025-05-19 09:37:58 [564ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘cpuUsageQuota’ = ‘-1.000000’
2025-05-19 09:37:58 [567ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘cpuVendor’ = ‘GenuineIntel’
2025-05-19 09:37:58 [571ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘desktopOrigin’ = ‘(0, 0)’
2025-05-19 09:37:58 [574ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘desktopSize’ = ‘1737x1423’
2025-05-19 09:37:58 [577ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘displayCount’ = ‘1’
2025-05-19 09:37:58 [580ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘displayRes_0’ = ‘1737x1423x32bit@60Hz’
2025-05-19 09:37:58 [583ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘environmentName’ = ‘Individual’
2025-05-19 09:37:58 [586ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘externalBuild’ = ‘1’
2025-05-19 09:37:58 [589ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘gpuDriver_0’ = ‘550.127’
2025-05-19 09:37:58 [592ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘gpuVRAM_0’ = ‘51797557248’
2025-05-19 09:37:58 [595ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘gpu_0’ = ‘NVIDIA A40-48Q’
2025-05-19 09:37:58 [598ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘kitRendererDriverVersion’ = ‘550.127’
2025-05-19 09:37:58 [603ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lastCommand’ = ‘CreateAttrCommand(node=?,attr_name=state:sdp_intergraph_downstream_node_handles,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?)’
2025-05-19 09:37:58 [606ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lastCommands’ = ‘SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),Group,FramePrimsCommand(prim_to_move=/OmniverseKit_Persp,prims_to_frame=?,time_code=?,usd_context_name=,aspect_ratio=1.7777777777777777),ChangePropertyCommand(prop_path=/OmniverseKit_Persp.omni:kit:centerOfInterest,value=?,prev=?,type_to_create_if_not_exist=?,usd_context_name=,is_custom=True,variability=?),TransformPrimSRTCommand(path=/OmniverseKit_Persp,new_translation=?,time_code=?,had_transform_at_key=False,usd_context_name=),SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),CreateAttrCommand(node=?,attr_name=state:sdp_intergraph_downstream_node_handles,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?),CreateAttrCommand(node=?,attr_name=state:sdp_intergraph_downstream_node_handles,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?),CreateAttrCommand(node=?,attr_name=state:sdp_intergraph_downstream_node_handles,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?),CreateAttrCommand(node=?,attr_name=state:sdp_intergraph_downstream_node_handles,attr_type=?,attr_port=?,attr_default=?,attr_extended_type=?)’
2025-05-19 09:37:58 [609ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_isaacSim_buildBranch’ = ‘HEAD’
2025-05-19 09:37:58 [612ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_isaacSim_buildDate’ = ‘Tue Jan 28 03:59:39 2025 +0000’
2025-05-19 09:37:58 [615ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_isaacSim_buildHash’ = ‘f59b300’
2025-05-19 09:37:58 [618ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_isaacSim_buildRepo’ = ‘https://gitlab-ci-token@gitlab-master.nvidia.com/omniverse/isaac/omni_isaac_sim.git’
2025-05-19 09:37:58 [623ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_isaacSim_buildVersion’ = ‘4.5.0-rc.36’
2025-05-19 09:37:58 [626ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_physx_buildBranch’ = ‘HEAD’
2025-05-19 09:37:58 [629ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_physx_buildDate’ = ‘MISSING PHYSICS_BUILD_DATE’
2025-05-19 09:37:58 [635ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_physx_buildHash’ = ‘c80d589’
2025-05-19 09:37:58 [638ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_physx_buildRepo’ = ‘gitlab-master.nvidia.com/omniverse/physics’
2025-05-19 09:37:58 [641ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘lib_physx_buildVersion’ = ‘106.5.7’
2025-05-19 09:37:59 [644ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘memoryStats’ = ‘(avail/total) RAM: 350.143/377.702GB, Swap: 1.90625/1.90625GB, VM: 1.71799e+10/1.71799e+10GB’
2025-05-19 09:37:59 [647ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘nvidia-smi’ = ’
==============NVSMI LOG==============
Timestamp : Mon May 19 11:36:16 2025
Driver Version : 550.127.05
CUDA Version : 12.4
Attached GPUs : 1
GPU 00000000:02:01.0
Product Name : NVIDIA A40-48Q
Product Brand : NVIDIA RTX Virtual Workstation
Product Architecture : Ampere
Display Mode : Enabled
Display Active : Disabled
Persistence Mode : Enabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-f3fdd1cb-1dd4-11b2-8a21-977750d759ff
Minor Number : 0
VBIOS Version : 00.00.00.00.00
MultiGPU Board : No
Board ID : 0x201
Board Part Number : N/A
GPU Part Number : 2235-895-A1
FRU Part Number : N/A
Module ID : N/A
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : VGPU
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
vGPU Software Licensed Product
Product Name : NVIDIA RTX Virtual Workstation
License Status : Licensed (Expiry: 2025-5-20 6:35:10 GMT)
GPU Reset Status
Reset Required : N/A
Drain and Reset Recommended : N/A
GSP Firmware Version : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x02
Device : 0x01
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x0
Device Id : 0x223510DE
Bus Id : 00000000:02:01.0
Sub System Id : 0x14E010DE
GPU Link Info
PCIe Generation
Max : N/A
Current : N/A
Device Current : N/A
Device Max : N/A
Host Max : N/A
Link Width
Max : N/A
Current : N/A
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : N/A
Replay Number Rollovers : N/A
Tx Throughput : N/A
Rx Throughput : N/A
Atomic Caps Inbound : N/A
Atomic Caps Outbound : N/A
Fan Speed : N/A
Performance State : P0
Clocks Event Reasons : N/A
Sparse Operation Mode : N/A
FB Memory Usage
Total : 49152 MiB
Reserved : 3984 MiB
Used : 273 MiB
Free : 44896 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : N/A
OFA : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
ECC Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable Parity : N/A
SRAM Uncorrectable SEC-DED : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
SRAM Threshold Exceeded : N/A
Aggregate Uncorrectable SRAM Sources
SRAM L2 : N/A
SRAM SM : N/A
SRAM Microcontroller : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : N/A
GPU T.Limit Temp : N/A
GPU Shutdown Temp : N/A
GPU Slowdown Temp : N/A
GPU Max Operating Temp : N/A
GPU Target Temperature : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
GPU Memory Power Readings
Power Draw : N/A
Module Power Readings
Power Draw : N/A
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 7250 MHz
Video : 1290 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Video : N/A
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : N/A
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 877283
Type : C
Used GPU Memory : 260 MiB
2025-05-19 09:37:59 [652ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘osDistro’ = ‘ubuntu’
2025-05-19 09:37:59 [655ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘osName’ = ‘22.04.5 LTS (Jammy Jellyfish)’
2025-05-19 09:37:59 [658ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘osVersion’ = ‘22.04.5’
2025-05-19 09:37:59 [664ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘portableMode’ = ‘0’
2025-05-19 09:37:59 [667ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘primaryDisplayRes’ = ‘1737x1423x32bit@60Hz’
2025-05-19 09:37:59 [670ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘runEnvironment’ = ‘Individual’
2025-05-19 09:37:59 [672ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘runningInContainer’ = ‘0’
2025-05-19 09:37:59 [675ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘shaderdb_debugSymbols’ = ‘0’
2025-05-19 09:37:59 [678ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘shaderdb_dumpIncludeOverrides’ = ‘0’
2025-05-19 09:37:59 [681ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘shaderdb_dumpIntermediates’ = ‘0’
2025-05-19 09:37:59 [685ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘shaderdb_obfuscateCode’ = ‘1’
2025-05-19 09:37:59 [690ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘shaderdb_optimizationLevel’ = ‘1’
2025-05-19 09:37:59 [693ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘systemInfo’ = ’
| Driver Version: 550.127.05 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA A40-48Q | Yes: 0 | | 49398 MB | 10de | 0 |
| | | | | | 2235 | f3fdd1cb.. |
| | | | | | 2 | |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.8.0-59-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: Intel(R) Xeon(R) Platinum 8362 CPU @ 2.80GHz
| Cores: 12 | Logical Cores: 12
| Total Memory (MB): 386766 | Free Memory: 366327
| Total Page/Swap (MB): 1951 | Free Page/Swap: 1951
2025-05-19 09:37:59 [696ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘telemetrySessionId’ = ‘17030177844392536663’
2025-05-19 09:37:59 [700ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘terminatedByAbort’ = ‘0’
2025-05-19 09:37:59 [703ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘totalRamBareMetalMB’ = ‘386766’
2025-05-19 09:37:59 [706ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘totalRamLimitedMB’ = ‘386766’
2025-05-19 09:37:59 [709ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘totalSwapBareMetalMB’ = ‘1951’
2025-05-19 09:37:59 [712ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘totalSwapLimitedMB’ = ‘1951’
2025-05-19 09:37:59 [715ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘userId’ = ‘default’
2025-05-19 09:37:59 [720ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘workingDirectory’ = ‘/home/’
2025-05-19 09:37:59 [723ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash report files for upload:
2025-05-19 09:37:59 [726ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ‘upload_file_minidump’ = ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip’
2025-05-19 09:38:00 [2,247ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] uploaded minidump: file: ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip’, code:200, response:
2025-05-19 09:38:00 [2,252ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] f41b4f40-3494-11f0-954c-0637ad1da0ab
2025-05-19 09:38:00 [2,255ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip’ (use setting “/crashreporter/preserveDump=true” to save)
2025-05-19 09:38:00 [2,259ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip’ with 10 retries remaining.
2025-05-19 09:38:00 [2,262ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip.toml’
2025-05-19 09:38:00 [2,269ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘/opt/nvidia-omniverse/data/Kit/Isaac-Sim Full/4.5/80041d64-970d-4d5b-5e5ec3b7-f9decbfa.dmp.zip.toml’ with 10 retries remaining.
terminate called after throwing an instance of ‘std::length_error’
what(): basic_string::resize
Killed
Additional Information
What I’ve Tried
As a work around I had to add my trees as references programatically.
