Isaac sim 4.5.0 crashed when following ros2 navigation tutorial
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: 4060ti
  • Driver Version: 570.133.20
Topic Description
Detailed Description
I was trying to complete the ROS navigation tutorial in Isaac Sim 4.5.0. When it reached the occupancy map calculation stage, Isaac Sim crashed. (ROS 2 Navigation — Isaac Sim Documentation)
Steps to Reproduce
  1. open isaac sim
  2. follow the tutorial to occupancy map step7
  3. crash
    (Add more steps as needed)
Error Messages
025-06-29 03:44:14 [100,737ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2025-06-29 03:44:14 [100,737ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/fg/isaac/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/impl/simulation_manager.py”, line 111, in _warm_start
2025-06-29 03:44:14 [100,737ms] [Error] [omni.kit.app._impl] [py stderr]: SimulationManager.physx_interface.update_simulation(SimulationManager.get_physics_dt(), 0.0)
2025-06-29 03:44:14 [100,737ms] [Error] [omni.kit.app.impl] [py stderr]: RuntimeError: Used null prim
2025-06-29 03:44:14 [100,739ms] [Error] [omni.physx.plugin] Subscription cannot be changed during the event call.
terminate called after throwing an instance of 'pxrInternal_v0_22__pxrReserved
::UsdExpiredPrimAccessError’
what(): Used null prim
2025-06-29 03:44:15 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-06-29 03:44:15 [31ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into ‘/home/fg/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/99f0874f-0ee4-4582-468e72b7-709efcb6.dmp.zip’ for upload.
2025-06-29 03:44:15 [264ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘/home/fg/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/99f0874f-0ee4-4582-468e72b7-709efcb6.dmp’ with 10 retries remaining.
2025-06-29 03:44:15 [268ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘/home/fg/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/99f0874f-0ee4-4582-468e72b7-709efcb6.dmp.toml’ with 10 retries remaining.
2025-06-29 03:44:15 [282ms] [Error] [carb.crashreporter-breakpad.plugin] ‘crashreport.gui’ exited with code 127
2025-06-29 03:44:15 [286ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘/home/fg/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/99f0874f-0ee4-4582-468e72b7-709efcb6.dmp.zip’
2025-06-29 03:44:15 [289ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] preventing upload of minidump due to user opt-out: ‘/home/fg/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/99f0874f-0ee4-4582-468e72b7-709efcb6.dmp.zip’
2025-06-29 03:44:15 [291ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] dump file size is 469341 bytes, file is readable.
2025-06-29 03:44:15 [294ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 15808 thread 15808
2025-06-29 03:44:15 [296ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2025-06-29 03:44:15 [299ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] BuildGitlabJobID = ‘128178599’
2025-06-29 03:44:15 [302ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘180.6+release.7436.c5558fdf.gl’
2025-06-29 03:44:15 [304ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Sun Jun 29 03:44:15 2025 GMT’
2025-06-29 03:44:15 [307ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2025-06-29 03:44:15 [309ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘99f0874f-0ee4-4582-468e72b7-709efcb6’
2025-06-29 03:44:15 [312ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] LastUploadStatus = ‘0’
2025-06-29 03:44:15 [314ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2025-06-29 03:44:15 [317ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy’ successfully wrote info to ‘/home/fg/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/99f0874f-0ee4-4582-468e72b7-709efcb6.py.txt’’
2025-06-29 03:44:15 [319ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2025-06-29 03:44:15 [322ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1751168553’
2025-06-29 03:44:15 [325ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2025-06-29 03:44:15 [327ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘102’
2025-06-29 03:44:15 [330ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2025-06-29 03:44:15 [332ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui’ exited with code 127’
2025-06-29 03:44:15 [335ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘106.5.0+release.162521.d02c707b.gl’
2025-06-29 03:44:15 [337ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_enabled = ‘1’
2025-06-29 03:44:15 [340ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_flags = ‘3’
2025-06-29 03:44:15 [342ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_status = ‘auto-enabled’
2025-06-29 03:44:15 [345ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_version = ‘2024.1’
2025-06-29 03:44:15 [347ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Isaac-Sim Full’
2025-06-29 03:44:15 [350ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘started’
2025-06-29 03:44:15 [353ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘4.5.0’
2025-06-29 03:44:15 [355ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘’
2025-06-29 03:44:15 [358ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘release’
2025-06-29 03:44:15 [360ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘gl’
2025-06-29 03:44:15 [363ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildConfig = ‘release’
2025-06-29 03:44:15 [365ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobName = ‘kit-build-release-linux-x86_64’
2025-06-29 03:44:15 [368ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobStage = ‘kit-build’
2025-06-29 03:44:15 [371ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabPipelineID = ‘21399756’
2025-06-29 03:44:15 [373ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘d02c707b’
2025-06-29 03:44:15 [376ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘106’
2025-06-29 03:44:15 [378ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘5’
2025-06-29 03:44:15 [381ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘162521’
2025-06-29 03:44:15 [383ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘0’
2025-06-29 03:44:15 [386ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘106.5.0’
2025-06-29 03:44:15 [389ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteFrameworkVersion = ‘180.6+release.7436.c5558fdf.gl’
2025-06-29 03:44:15 [391ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteSdkVersion = ‘180.6+release.7436.c5558fdf.gl’
2025-06-29 03:44:15 [394ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘./kit/kit ./apps/isaacsim.exp.full.kit --ext-folder ./apps’
2025-06-29 03:44:15 [396ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuCoreLimited = ‘16’
2025-06-29 03:44:15 [399ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuId = ‘Intel64 Family 25 Model 97 Stepping 2’
2025-06-29 03:44:15 [401ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuLogicalCoresBareMetal = ‘16’
2025-06-29 03:44:15 [404ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuName = ‘AMD Ryzen 7 7800X3D 8-Core Processor’
2025-06-29 03:44:15 [406ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuPhysicalCoresBareMetal = ‘8’
2025-06-29 03:44:15 [409ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuUsageQuota = ‘-1.000000’
2025-06-29 03:44:15 [411ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuVendor = ‘AuthenticAMD’
2025-06-29 03:44:15 [414ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopOrigin = ‘(0, 0)’
2025-06-29 03:44:15 [417ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopSize = ‘3440x1440’
2025-06-29 03:44:15 [419ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayCount = ‘1’
2025-06-29 03:44:15 [422ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayRes_0 = ‘3440x1440x32bit@60Hz’
2025-06-29 03:44:15 [424ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘Individual’
2025-06-29 03:44:15 [427ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] externalBuild = ‘1’
2025-06-29 03:44:15 [429ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] extraExts = ‘isaacsim.ros2.bridge-4.1.15’
2025-06-29 03:44:15 [432ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_0 = ‘570.133’
2025-06-29 03:44:15 [434ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_1 = ‘0x5c02001’
2025-06-29 03:44:15 [437ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_0 = ‘17175674880’
2025-06-29 03:44:15 [440ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_1 = ‘11297447936’
2025-06-29 03:44:15 [442ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_0 = ‘NVIDIA GeForce RTX 4060 Ti’
2025-06-29 03:44:15 [445ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_1 = ‘AMD Unknown (RADV RAPHAEL_MENDOCINO)’
2025-06-29 03:44:15 [447ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] kitRendererDriverVersion = ‘570.133’
2025-06-29 03:44:15 [450ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommand = ‘SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True)’
2025-06-29 03:44:15 [452ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommands = ‘SetLightingMenuModeCommand(lighting_mode=,usd_context_name=),SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),ToggleActivePrims(stage_or_context=?,prim_paths=?,active=False),SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True)’
2025-06-29 03:44:15 [455ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildBranch = ‘HEAD’
2025-06-29 03:44:15 [457ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildDate = ‘Tue Jan 28 03:59:39 2025 +0000’
2025-06-29 03:44:15 [460ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildHash = ‘f59b300’
2025-06-29 03:44:15 [465ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildVersion = ‘4.5.0-rc.36’
2025-06-29 03:44:15 [468ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildBranch = ‘HEAD’
2025-06-29 03:44:15 [470ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildDate = ‘MISSING PHYSICS_BUILD_DATE’
2025-06-29 03:44:15 [473ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildHash = ‘c80d589’
2025-06-29 03:44:15 [478ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildVersion = ‘106.5.7’
2025-06-29 03:44:15 [480ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 20.3789/30.5647GB, Swap: 0/0GB, VM: 1.71799e+10/1.71799e+10GB’
2025-06-29 03:44:15 [483ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = ’
==============NVSMI LOG==============
Timestamp : Sun Jun 29 11:42:34 2025
Driver Version : 570.133.20
CUDA Version : 12.8
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA GeForce RTX 4060 Ti
Product Brand : GeForce
Product Architecture : Ada Lovelace
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Disabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-d2e6247c-c629-9bd2-d137-b9d40c9a0ddb
Minor Number : 0
VBIOS Version : 95.06.34.00.95
MultiGPU Board : No
Board ID : 0x100
Board Part Number : N/A
GPU Part Number : 2803-350-A1
FRU Part Number : N/A
Platform Info
Chassis Serial Number : N/A
Slot Number : N/A
Tray Index : N/A
Host ID : N/A
Peer Type : N/A
Module Id : 1
GPU Fabric GUID : N/A
Inforom Version
Image Version : G002.0000.00.03
OEM Object : 2.0
ECC Object : N/A
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Reset Status
Reset Required : Requested functionality has been deprecated
Drain and Reset Recommended : Requested functionality has been deprecated
GPU Recovery Action : None
GSP Firmware Version : 570.133.20
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x0
Device Id : 0x280310DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x28051ED3
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Device Current : 1
Device Max : 4
Host Max : 4
Link Width
Max : 8x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 7450 KB/s
Rx Throughput : 7450 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : 30 %
Performance State : P8
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Sparse Operation Mode : N/A
FB Memory Usage
Total : 16380 MiB
Reserved : 422 MiB
Used : 16 MiB
Free : 15943 MiB
BAR1 Memory Usage
Total : 16384 MiB
Used : 3 MiB
Free : 16381 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
GPU : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
DRAM Encryption Mode
Current : N/A
Pending : N/A
ECC Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable Parity : N/A
SRAM Uncorrectable SEC-DED : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
SRAM Threshold Exceeded : N/A
Aggregate Uncorrectable SRAM Sources
SRAM L2 : N/A
SRAM SM : N/A
SRAM Microcontroller : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 64 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 49 C
GPU T.Limit Temp : 34 C
GPU Shutdown T.Limit Temp : -7 C
GPU Slowdown T.Limit Temp : -2 C
GPU Max Operating T.Limit Temp : 0 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating T.Limit Temp : N/A
GPU Power Readings
Average Power Draw : 10.02 W
Instantaneous Power Draw : 10.01 W
Current Power Limit : 165.00 W
Requested Power Limit : 165.00 W
Default Power Limit : 165.00 W
Min Power Limit : 100.00 W
Max Power Limit : 165.00 W
GPU Memory Power Readings
Average Power Draw : N/A
Instantaneous Power Draw : N/A
Module Power Readings
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Power Smoothing : N/A
Workload Power Profiles
Requested Profiles : N/A
Enforced Profiles : N/A
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 1185 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 3105 MHz
SM : 3105 MHz
Memory : 9001 MHz
Video : 2415 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : N/A
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Route Recovery in progress : N/A
Route Unhealthy : N/A
Access Timeout Recovery : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 1770
Type : G
Used GPU Memory : 4 MiB
Capabilities
EGM : disabled
2025-06-29 03:44:15 [486ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘ubuntu’
2025-06-29 03:44:15 [488ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘22.04.4 LTS (Jammy Jellyfish)’
2025-06-29 03:44:15 [491ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘22.04.4’
2025-06-29 03:44:15 [493ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘0’
2025-06-29 03:44:15 [496ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] primaryDisplayRes = ‘3440x1440x32bit@60Hz’
2025-06-29 03:44:15 [498ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
2025-06-29 03:44:15 [501ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runningInContainer = ‘0’
2025-06-29 03:44:15 [503ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_debugSymbols = ‘0’
2025-06-29 03:44:15 [506ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIncludeOverrides = ‘0’
2025-06-29 03:44:15 [509ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIntermediates = ‘0’
2025-06-29 03:44:15 [511ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_obfuscateCode = ‘1’
2025-06-29 03:44:15 [514ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_optimizationLevel = ‘1’
2025-06-29 03:44:15 [516ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ’
| Driver Version: 570.133.20 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4060 Ti | Yes: 0 | | 16380 MB | 10de | 0 |
| | | | | | 2803 | d2e6247c.. |
| | | | | | 1 | |
| 1 | AMD Unknown (RADV RAPHAEL_MEND.. | | | 10774 MB | 1002 | 0 |
| | | | | | 164e | 00000000.. |
| | | | | | c | |
| OS: 22.04.4 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.4, Kernel: 6.8.0-60-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: AMD Ryzen 7 7800X3D 8-Core Processor
| Cores: 8 | Logical Cores: 16
| Total Memory (MB): 31298 | Free Memory: 25349
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
2025-06-29 03:44:15 [519ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘15197754924899304763’
2025-06-29 03:44:15 [522ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
2025-06-29 03:44:15 [524ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamBareMetalMB = ‘31298’
2025-06-29 03:44:15 [527ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamLimitedMB = ‘31298’
2025-06-29 03:44:15 [529ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapBareMetalMB = ‘0’
2025-06-29 03:44:15 [532ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapLimitedMB = ‘0’
2025-06-29 03:44:15 [534ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’
2025-06-29 03:44:15 [537ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/home//isaac’
2025-06-29 03:44:15 [539ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 15808 backtrace follows:
2025-06-29 03:44:15 [587ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2025-06-29 03:44:15 [627ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!pthread_kill+0x12c (./nptl/pthread_kill.c:44)
2025-06-29 03:44:15 [664ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!raise+0x16 (./signal/../sysdeps/posix/raise.c:27)
2025-06-29 03:44:15 [702ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libc.so.6!abort+0xd3 (./stdlib/abort.c:81 (discriminator 21))
2025-06-29 03:44:15 [712ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libstdc++.so.6!__cxa_throw_bad_array_new_length+0x552 (??:?)
2025-06-29 03:44:15 [722ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libstdc++.so.6!std::rethrow_exception(std::__exception_ptr::exception_ptr)+0x7c (??:?)
2025-06-29 03:44:15 [732ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libstdc++.so.6!__cxa_free_dependent_exception+0x79 (??:?)
2025-06-29 03:44:15 [742ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libstdc++.so.6!__gxx_personality_v0+0x99 (??:?)
2025-06-29 03:44:15 [751ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libgcc_s.so.1!_Unwind_GetTextRelBase+0x1ef4 (??:?)
2025-06-29 03:44:15 [761ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libgcc_s.so.1!_Unwind_Resume+0x12d (??:?)
2025-06-29 03:44:15 [766ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libomni.physx.plugin.so!std::_Hashtable<unsigned int, std::pair<unsigned int const, unsigned int>, std::allocator<std::pair<unsigned int const, unsigned int> >, std::__detail::_Select1st, std::equal_to, std::hash, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, false, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<std::pair<unsigned int const, unsigned int>, false>)+0x904e (??:?)
2025-06-29 03:44:15 [771ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libomni.physx.plugin.so!std::_Hashtable<char const
, std::pair<char const* const, std::pair<char const* const*, unsigned long> >, std::allocator<std::pair<char const* const, std::pair<char const* const*, unsigned long> > >, std::__detail::_Select1st, std::equal_to<char const*>, std::hash<char const*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, false, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<std::pair<char const* const, std::pair<char const* const*, unsigned long> >, false>)+0x4198 (??:?)
2025-06-29 03:44:15 [776ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libomni.stageupdate.plugin.so!ZNSt5dequeISt8functionIFvvEESaIS2_EE16_M_push_back_auxIJZN4omni5graph4exec8unstable15SerialScheduler8scheduleIZNS9_8ExecutorINS9_5INodeENS9_14ExecutionVisitENS9_17ExecutionNodeDataESA_NS9_25DefaultSchedulingStrategyENS9_9IExecutorEE16scheduleInternalISA_EENS9_6StatusEONS9_13ExecutionTaskEPNSt9enable_ifIXntsrNSI_11is_deferredIT_vEE5valueEvE4typeEEUlvE_EESK_OSP_NS9_14SchedulingInfoEEUlvE_EEEvDpOT
2025-06-29 03:44:15 [782ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libomni.graph.exec.plugin.so!_init+0x250f (??:0)
2025-06-29 03:44:15 [789ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: std::enable_if<!omni::graph::exec::unstable::Executor::is_deferred<omni::graph::exec::unstable::SerialScheduler, void>::value, void>::type
)::{lambda()#1}&&, omni::graph::exec::unstable::SchedulingInfo)::{lambda()#1}>::_M_manager(std::_Any_data&, std::_Any_data const&, std::_Manager_operation)+0x198a (??:?)
2025-06-29 03:44:15 [794ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.stageupdate.plugin.so!std::basic_string<char, std::char_traits, std::allocator >::basic_string(char const*, std::allocator const&)+0x384 (??:?)
2025-06-29 03:44:15 [801ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.graph.exec.plugin.so!_init+0x2f3c (??:0)
2025-06-29 03:44:15 [806ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.kit.exec.core.plugin.so!std::basic_string<char, std::char_traits, std::allocator >::~basic_string()+0x2798 (??:?)
2025-06-29 03:44:15 [812ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libomni.kit.exec.core.plugin.so!std::_Function_base::_Base_manager<omni::kit::exec::core::unstable::PassPipeline::_runPopulateTraversal(omni::graph::exec::unstable::IGraphBuilderContext*, omni::graph::exec::unstable::INodeGraphDef*)::{lambda(auto:1, omni::graph::exec::unstable::INode*, omni::graph::exec::unstable::INode*)#1}>::_M_manager(std::_Any_data&, std::_Any_data const&, std::_Manager_operation)+0xac4 (??:?)
2025-06-29 03:44:15 [818ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libomni.graph.exec.plugin.so!_init+0x126d (??:0)libcarb.events.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)+0x6d9a (??:?)
2025-06-29 03:44:15 [875ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libcarb.events.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)+0x7145 (??:?)
2025-06-29 03:44:15 [881ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libomni.timeline.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)+0x2cc9 (??:?)
2025-06-29 03:44:15 [887ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libomni.timeline.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)+0x3918 (??:?)
2025-06-29 03:44:15 [893ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libomni.timeline.plugin.so!carbOnPluginPreStartup+0xadf (??:?)
2025-06-29 03:44:15 [902ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libcarb.events.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)+0x6d9a (??:?)
2025-06-29 03:44:15 [911ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libcarb.events.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)+0x7145 (??:?)
2025-06-29 03:44:15 [921ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libcarb.events.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int ()(char, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)+0x7281 (??:?)
2025-06-29 03:44:15 [927ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libomni.kit.loop-isaac.plugin.so!std::char_traits::length(char const*)+0x1f3c (??:?)
2025-06-29 03:44:15 [934ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libomni.kit.loop-isaac.plugin.so!std::string::replace(unsigned long, unsigned long, char const*, unsigned long)+0x1125f (??:?)
2025-06-29 03:44:15 [943ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: libomni.kit.app.plugin.so!_init+0x7882 (??:0)
2025-06-29 03:44:16 [953ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libomni.kit.app.plugin.so!carbOnPluginPreStartup+0x211d (??:?)
2025-06-29 03:44:16 [956ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: kit!_init+0x910 (??:0)
2025-06-29 03:44:16 [993ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2025-06-29 03:44:16 [1,030ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2025-06-29 03:44:16 [1,033ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: kit!_start+0x29 (??:?)
Aborted (core dumped)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
Hi @cctgyh welcome to the community!
I just tried the tutorial and it works fine.
You log file says “what(): Used null prim”. It looks like something is wrong with your USD file.
Which scene are you using? Are you using the ROS2 carter navigation scene?
Hello!
Best regards,
