But when importing it to USD compose, this is the result:
…as you can see it is rotated by 90 degrees. I’ve tried several different Combinations of import options, but I cannot get USD compose to import it the right way.
@mati-nvidia would be great if you can have a look at this… we have a very important presentation next week and this is currently the last showstopper for us…
the problem here is that I’ve hundrets of other assets that loads fine, so I cannot change up, because I do not know what “up” ist for each asset.
I think the problem here is that the up-settings from the asset are not interpreted. Because even Windows -3D-Viewer opens this asset and the other assets that are loaded correctly in USD compose, in the correct way
