The following additional verification.
Check Environment
OS : Windows 10
Mem : 64 GB
GPU : NVIDIA RTX A5000 (VRAM 24GB)
Omniverse : Omniverse Create 2022.1.3
Verification details
Tested material reproducibility when importing glTF files converted to USD.
The following is a list of what was incorrect when each was verified.
The list is divided into two parts because the MDL of the material changes depending on whether the option “Import Materials as UsdPreviewSurface” is turned on or off.
Import Materials as UsdPreviewSurface : Off
- The scale of normalTexture is not stored (still 1.0)
- Alpha value of “baseColorFactor” is not reflected when texture is not specified in “alphaMode=BLEND”
Import Materials as UsdPreviewSurface : On
- Not multiplying when using baseColorFactor and baseColorTexture.
==> Can be handled with “inputs:scale” - Not multiplying when using metallicRoughnessTexture, roughnessFactor and metallicFactor.
==> Can be handled with “inputs:scale” - KHR_texture_transform is not reflected.
Files for verification
I have created glb files for verification.
Please use “Convert To USD” to convert to USD.
I have checked with RTX Interactive (PathTracing).
For scale confirmation of normal map
glTFTest_normalMap.glb (65.9 KB)
In glTF, set “scale” of “normalTexture”.
"doubleSided": true,
"name": "normal2_mat",
"normalTexture": {
"index": 1,
"scale": 0.5
"pbrMetallicRoughness": {
"baseColorFactor": [
0.800000011920929,
0.800000011920929,
0.800000011920929,
1
"metallicFactor": 0,
"roughnessFactor": 0.5
The normal map scale is not reflected in the USD.
Use BLEND in AlphaMode
glTFTest_AlphaMode_Blend.glb (130.2 KB)
In glTF, set Alpha of “baseColorFactor”.
"alphaMode": "BLEND",
"name": "blend_05_mat",
0.20823588967323303,
0.18150004744529724,
0.8000000715255737,
0.5
"roughnessFactor": 0.20000000298023224
If no texture is used, the Alpha of baseColorFactor is not reflected in the USD.
When using a texture without Alpha, the Alpha of the baseColorFactor is not reflected in the USD.
Multiplication of BaseColorMap and BaseColor
glTFTest_BaseColor.glb (56.9 KB)
In glTF, Set baseColorTexture and baseColorFactor.
"name": "tex2_mat",
0.08553679287433624,
0.1942881941795349,
0.4623614251613617,
1
"baseColorTexture": {
"index": 1
When UsdPreviewSurface.
When using baseColorTexture and baseColorFactor, the colors are not multiplied.
How about using “inputs:scale” in UsdPreviewSurface?
Use MetallicMap/RoughnessMap/roughnessFactor/metallicFactor
glTFTest_MetallicRoughnessMap.glb (41.9 KB)
In glTF, Set metallicRoughnessTexture, roughnessFactor and metallicFactor.
"name": "tex1_mat",
0.3932863771915436,
0.3932863771915436,
0.3932863771915436,
1
"roughnessFactor": 0.6,
"metallicFactor": 0.8,
"metallicRoughnessTexture": {
"index": 0
When using metallicRoughnessTexture, roughnessFactor and metallicFactor, the value are not multiplied.
Testing KHR_texture_transform
glTFTest_TextureTransform.glb (56.9 KB)
In glTF, Use “KHR_texture_transform” Extension.
"name": "tex2_mat",
"index": 1,
"extensions": {
"KHR_texture_transform": {
"scale": [
4,
2
Texture transformation of “KHR_texture_transform” is not reflected.
There are other items that may not be correct when converting from glTF to USD, and I will try to add them later.
