The simple Extension + Window code below (just replace an extension.py with it) is reloaded fine by Kit, after the file is saved from an editor, and the window displays the two created controls.
However, if the line with #ATTN is commented-out, after saving the python file twice, the extension window remains blank until Kit is shutdown. Even restoring the commented-out line no longer works, which is quite annoying.
I believe this happens because the reference to the ui.FloatSlider’s model somehow leaves the Window hanging, and after an extension reload, MyWindow._build_fn is again never called.
Is this a Kit issue that you plan to fix or is it “by design” behavior?
from functools import partial
import omni.ext
import omni.ui as ui
class MyWindow(ui.Window):
def __init__(self, title: str = None, delegate=None, **kwargs):
print("win.__init__")
super().__init__(title, **kwargs)
self.frame.set_build_fn(self._build_fn)
def destroy(self):
print("win.destroy")
self.proj_scale_model = None #ATTN: comment this line and save extension twice - window controls no longer appear
super().destroy()
def _build_fn(self):
print(f"win._build_fn {self.visible}")
# Called to build the UI once the window is visible
with ui.ScrollingFrame():
with ui.VStack(height=0):
self._sel_button = ui.Label("My Label")
self.proj_scale_model = ui.FloatSlider(min=0, max=100).model
self.proj_scale_model.add_value_changed_fn( self.act )
def act(self, m):
print("act", m.as_float)
class MyExtension(omni.ext.IExt):
def on_startup(self, ext_id):
print("MyExtension startup")
self._window = None
ui.Workspace.set_show_window_fn("Name", partial(self.show_window, None))
ui.Workspace.show_window("Name")
def show_window(self, menu, value):
print("ext.show_window", value, self._window)
self._window = MyWindow("Name", width=300, height=300)
def on_shutdown(self):
print("MyExtension shutdown")
ui.Workspace.set_show_window_fn("Name", None)
if self._window:
self._window.destroy()
self._window = None
