CAD importer - Revit phases
When using the CAD importer to bring native Revit data into a scene all phases are included, which makes working with the file in Omniverse problematic in that all phases and geometry is assembled into the scene hierarchy. Is there a way to filter these phases without having to go back to Revit?
May I suggest, that rather than using our built in CAD converter to import revit file into USD Composer, you should download and install the official Revit Connector for Omniverse from our Launcher. It has all of the extra tools you need, including respecting phasing when exporting.
Hi Richard, thanks for coming back to me. Unfortunately we don’t have access to Revit so this isn’t an option for us. We receive files from many different clients, asking them all to install the connector and export to Omniverse isn’t really an option either.
Are there any plans to have feature parity with the Revit exporter? Also noticed the metadata/BIM properties don’t come through with the CAD importer.
You don’t have access to Revit ? So then how do you normally receive and import Revit data into your workflow before using Omniverse ? What would you import the Revit files into ? You could ask for an fbx file also.
