Hi, I know that we can import usd. files from Nucleus Server to 3ds max and Maya.
Also, I got the reply that Rhino and SketchUP are not available to do that right now.
Is Revit’s situation same with Rhino and Sketchup?
When will it be available to import the usd. file in Revit.
Hi, I found that I can connect to the file from server.
But it seems will crash during import progress. Please see the attach video
Import is not supported for Revit at this time.
Brian
Your ‘Connect’ is to a non-existent USD and that is just a bug, unfortunately. We will fix that.
Brian
Hi @bharrison,
Thank you for the rapid reply.
Is there any update about this import function of Revit?
Many thanks
