activating both the USD and the Omniverse Plugin leads the UE 4.26 to crash without the possibility to restart?
I activated both because i would like to import the rhino geometry that has been exported to a usd with the
omniverse rhino plugin.
the “SendToView” function has a shortcoming which is that every time i execute this command a new “SendToView” Folder is created. I would like to have a static USD file that both Rhino, UE and Ominverse View are referenced to.
Now I published the USD file from Rhino with the “Publish” button.
Unfortunately the saved “Shell_Option_V3.gh.usd” is neither recognized by UE or can be imported…
@bharrison - for the Rhino “SendToView” creating a new folder every time issue
As for why Unread Editor won’t open “Shell_Option_V3.gh.usd”, I’m not exactly sure. I thought it was due to the extra “.” in the filename, but I’m able to open files named aaaa_bbbbb.gh.usd properly. I’d love to dig further into this and figure out why it’s not working, can you possibly provide us with a USD file so we can reproduce and possibly fix the issue?
Send to View is intended to create a new folder each time. The folder name is a compilation of the name of the file being exported and a date stamp. This allows multiple iterations to be created quickly without overwriting each other.
