Originally published at: Calculating and Synchronizing Time with the Precision Timing Protocol on the NVIDIA Spectrum Switch | NVIDIA Technical Blog
The NVIDIA Spectrum switch supports accurate and scalable Precision Timing Protocol (PTP).
jwitsoe
1
Related topics
Topic | Replies | Views | Activity | |
Open Source Time Synchronization Services for Data Center Operators | 0 | 400 | March 6, 2023 | |
Disabling PTP causes WiFi to shutdown | 16 | 536 | November 17, 2021 | |
Discrepancy in NTP Timestamps with Multiple RTSP Sources | 8 | 152 | August 27, 2024 | |
Time not synchronized between two nx devices with ptp | 29 | 3909 | July 23, 2021 | |
NVPPS PTP synchronization | 22 | 1781 | March 20, 2024 | |
How & When the basetime of NTP_timestamp in the NvDsFrameMeta is updated by RTCP sender report | 10 | 37 | April 22, 2025 | |
Time sensitive networking [TSN] on NX | 154 | 13807 | August 7, 2022 | |
Jetson AGX Xavier both NICs use Same PTP Hardware Clock | 4 | 1252 | November 17, 2021 | |
RTCP timestamp delay | 11 | 377 | July 16, 2024 | |
SN2100 NTP Debugging | 12 | 648 | March 8, 2024 |
