I am trying to connect to omniverse nucleus using omni.client. I am currently in docker container with base image isaac-sim, and I want to call nucleus hosted on the local machine outside of the container. I have shared the nucleus, and I am trying to access it using my IP, however I am getting a connection error. I have removed --network host from the run command of the container because I am bound to other containers, thus it is not an option to use network host. How can I specify to omni.client the ip/path of the hosted nucleus so I can interact with it.
Thank you for your help
