Can I use the Sabertooth 32A Motor driver with a Nano Dev Kit?
Hello! I am looking to build an autonomous robot that uses semantic segmentation to navigate through vineyards. TLDR we’re looking at robot parts and one of the motor drivers we are looking at is the Sabertooth 32a Dual motor driver, I’m wondering if the Jetson Nano can talk to this via the UART Serial pins, as the motor driver can receive TTL Serial.
Yes, that should work, you can refer to other developers’ issue: Search results for ‘Sabertooth nano’ - NVIDIA Developer Forums
Thank you so much!
