Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.7
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
<Please provide details about your query/application pipeline/usecase/pictures here >
The CAN bus has bus error if CAN I/F of Orin-X EVB is connected to vehicle.
- I found that 2 channels CAN I/F are connected to Orin-X. But these channels are connected to MCU(AURIX) together. Can it be occurred by MCU?
- If it can, How I can prevent these in MCU side? MCU binary is default binary which is supported from Drive OS SDK.
The USB CAN device is connected without error. DRIVE OS 6.0.7 is used to initilize USB CAN device.
And the CAN I/F initialization is executed same like embedded CAN I/F (mttcan).
sudo ip link set can0 type can bitrate 500000 sample-point 0.8 dbitrate 2000000 dsample-point 0.8 fd on
sudo ip link set up can0
The mttcan make error only.
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
