Orin CAN doesn't work on DRIVE OS 6.06
Software Version
DRIVE OS 6.0.8.1
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-200)
other
SDK Manager Version
[*] 1.9.3.10904
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Hi Nvidia:
I config the CAN follow the url Controller Area Network (CAN) — Jetson Linux<br/>Developer Guide 34.1 documentation,
Here is teh steps:
modprobe can
modprobe can_raw
modprobe mttcan
ip link set can0 up type can bitrate 500000 dbitrate 1000000 berr-reporting on fd on
cansend can0 123#12345678
when I ran command “cansend can0 123#12345678”, it printed the below information:
root@tegra-ubuntu:/home/nvidia# [ 351.088733] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.088744] mttcan c310000.mttcan can0: IR 0x8010000 PSR 0x71d
[ 351.088766] mttcan c310000.mttcan can0: entered error passive state
[ 351.088768] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.088771] mttcan c310000.mttcan can0: IR 0x9800000 PSR 0x77d
[ 351.088808] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.088810] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77d
[ 351.088860] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.088862] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77d
[ 351.088912] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.088913] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77d
[ 351.089144] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.089145] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77d
[ 351.089172] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.089174] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77d
[ 351.089223] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.089225] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77d
[ 351.089275] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.089278] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77d
[ 351.089327] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.089328] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77d
[ 351.089379] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.089431] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.089483] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 351.089542] mttcan c310000.mttcan can0: entered bus off state
[ 351.089543] mttcan c310000.mttcan can0: Bit0 Error Detected
Please help to fix this issue. Thanks.
Hi @zhangjing92
Supposed you should get the support via NVonline, please discuss with your internal team first.
