###SDK Manager 1.1.0.6343
can not install Jetson SDK Components in Target Component
this is the info
Could you confirm on your host PC, you can login the device through 192.168.55.1?
You need to init user name on the device, before execute step4.
Before step4, check it through command line would make the issue more clear.
Same as what @juns said, but added information. The required login was specifically user “nvidia” at 192.168.55.1. If you did not complete the first time login setup after a flash on more recent releases, then this account/pass will not yet exist. Did you complete first login account setup?
