I am trying to use the CAN peripheral of Jetson AGX Xavier. I run jetson with linux 5.10.104 tegra.
I follow the register setup as mentioned in other forum topics and have the CAN working in loopback test. But when I connect the tx and rx pins to Microchip CAN bus analyzer to verify the message through the pins there is no response. I tried most of the solution discussed in other topics, but they all use 4.9 tegra. So please could you support me to fix this issue?
Thank you
