I have some jetson orin nano 4g and jetson orin nano 8g motherboards, can these two motherboards use an image so that my power will not be affected? I found that the solid-state use of these two motherboards with each other would cause some power abnormalities when I used jetpack 5.1 before, but now it is not. Please tell me if there is any problem with doing that
Below are the power mode of both.
Jetson Orin Nano 8GB Modes: 7W | 15W | 25W (MAXN_SUPER)
Jetson Orin Nano 4GB Modes: 7W | 10W | 25W (MAXN_SUPER)
I mean the two motherboards use the same solid state, can both use these power modes?
What’s that meaning?
I have obtained a solid state that can open maxn mode by swiping the jetson orin nano 8g. Now I want to use this solid state for jetson orin 4g. Is there any problem?
I don’t get what the “solid state” is. Is it a board?
NO,it is NVME ,A carrier loaded with images
You mean to use same image to get same power on both 8G and 4G modules? That’s not guaranteed as the real power consumption depends on use case and module itself.
yeah, thanks for your answer. I’ll try
