I guess L4T 24.1 supports only CUDNN v5. And I have a requirement to run TensorRT 3.0 on 24.1 OS, without updating to Jetpack to 3.3.
For this I did the following steps:
-Copied the dependent TensorRT binaries from Jetpack 3.3 to L4T 24.1 device.
-Copied the libcublas.so.9.0, libcudart.so.9.0.
-Copied the libcudnn7.0 also.
-Compile and Link a sample/samplePlugin with the above include and libraies.
-While Running: I get this error.
ERROR: cudnnLayerUtils.cpp (288) - Cuda Error in smVersion: 35
terminate called after throwing an instance of ‘nvinfer1::CudaError’
I understand that the above is not the right way but still I gave it a try, thinking I may get lucky on TX1, since I was able to run the samplePlugin sample with CUDA 8.0 and CUDNN 7.0, on my desktop machine with Nvidia GTX 1070
But Can anyone help me to update from cuda8.0 to cuda9.0 and >cudnn7.0 on L4T 24.1 OS, so that I can run TensorRT 3.0 ? Is it possible? If not why?
