we need to run containers in swarm mode. but swarm does not work with privileged
[root@transcoder4 ~]# docker -v
Docker version 20.10.8, build 3967b7d
[root@transcoder4 ~]# nvidia-smi
Thu Aug 5 16:45:12 2021
| NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| 33% 43C P0 36W / 180W | 0MiB / 8119MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
[root@transcoder4 ~]# docker run --privileged --rm --runtime=nvidia izone/device-query
/usr/local/cuda/samples/1_Utilities/deviceQuery/deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA GeForce GTX 1080"
CUDA Driver Version / Runtime Version 11.4 / 10.0
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 8119 MBytes (8513585152 bytes)
(20) Multiprocessors, (128) CUDA Cores/MP: 2560 CUDA Cores
GPU Max Clock rate: 1734 MHz (1.73 GHz)
Memory Clock rate: 5005 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 2097152 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.4, CUDA Runtime Version = 10.0, NumDevs = 1
Result = PASS
[root@transcoder4 ~]# docker run --rm --runtime=nvidia izone/device-query
cudaGetDeviceCount returned 38
-> no CUDA-capable device is detected
Result = FAIL
[root@transcoder4 ~]# cat /etc/docker/daemon.json
"default-runtime": "nvidia",
"runtimes": {
"nvidia": {
"path": "/usr/bin/nvidia-container-runtime",
"runtimeArgs": []
[root@transcoder4 ~]# cat /etc/nvidia-container-runtime/config.toml
disable-require = false
swarm-resource = "DOCKER_RESOURCE_GPU"
accept-nvidia-visible-devices-envvar-when-unprivileged = true
accept-nvidia-visible-devices-as-volume-mounts = true
[nvidia-container-cli]
#root = "/run/nvidia/driver"
#path = "/usr/bin/nvidia-container-cli"
environment = []
#debug = "/var/log/nvidia-container-toolkit.log"
#ldcache = "/etc/ld.so.cache"
user = "root:video"
load-kmods = true
no-cgroups = true
#user = "root:video"
ldconfig = "@/sbin/ldconfig"
[nvidia-container-runtime]
debug = "/var/log/nvidia-container-runtime.log"
