Hi ! When I build kernel modules , A error appeared:“ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/xx.o: No such file or directory”
I don’t know if it’s caused by gcc,hope someone can help me,thanks
All log is as follows:
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Jun 27 03:26:01 2018
installer version: 390.67
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 4 CPUs online; setting concurrency level to 4.
→ Installing NVIDIA driver version 390.67.
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.14.32-rancher2/build’
→ Kernel output path: ‘/lib/modules/4.14.32-rancher2/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j4 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.14.32-rancher2/build” SYSOUT=“/lib/modules/4.14.32-rancher2/build”’…
rm -f -r conftest
make[1]: Entering directory ‘/lib/modules/4.14.32-rancher2/build’
make[1]: Leaving directory ‘/lib/modules/4.14.32-rancher2/build’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.14.32-rancher2/build” SYSOUT=“/lib/modules/4.14.32-rancher2/build”’…
SYMLINK /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: remap_pfn_range
CONFTEST: hash__remap_4k_pfn
CONFTEST: follow_pfn
CONFTEST: INIT_WORK
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: kmem_cache_create
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_free
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_disable_all
CONFTEST: drm_atomic_helper_set_config
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: kernel_write
CONFTEST: strnstr
CONFTEST: iterate_dir
CONFTEST: kstrtoull
CONFTEST: backlight_properties_type
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_old_atomic_state_iterators_present
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
LD [M] /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia.o
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-frontend.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-instance.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gpu-numa.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-acpi.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-chrdev.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-cray.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-dma.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gvi.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-i2c.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mempool.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mmap.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-p2p.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pat.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-procfs.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-usermap.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vm.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vtophys.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-interface.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-mlock.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-pci.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-registry.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-usermap.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-modeset-interface.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pci-table.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q-selftest.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-memdbg.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-ibmnpu.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-report-err.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv_uvm_interface.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nvlink_linux.o: No such file or directory
LD [M] /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset.o
scripts/Makefile.build:574: recipe for target ‘/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia.o’ failed
make[2]: *** [/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia.o] Error 1
ld -r -o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-frontend.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-instance.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-acpi.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-chrdev.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-cray.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-dma.o /tmp/selfgz18121/NVIDIA-Linux-x86_64
-390.67/kernel/nvidia/nv-gvi.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-i2c.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mempool.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mmap.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-p2p.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pat.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-procfs.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-usermap.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vm.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vtophys.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-mlock.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-pci.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-registry.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-usermap.o /tmp/selfgz18121/NVIDIA
-Linux-x86_64-390.67/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pci-table.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-memdbg.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-report-err.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nvlink_linux.o
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm_utils.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm_common.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm_linux.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/nvstatus.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/nvCpuUuid.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_tools.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_global.o: No such file or directory
LD [M] /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm.o
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nvidia-modeset-linux.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_isr.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_procfs.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_va_space.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_semaphore.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_mem.o: No such file or directoryscripts/Makefile.build:574: recipe for target ‘/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset.o’ failed
make[2]: *** [/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset.o] Error 1
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_rm_mem.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_channel.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_lock.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_hal.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_tree.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_allocator.o: No such file or directory
ld -r -o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nvidia-modeset-linux.o
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_va_range.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_va_block.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_group.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_access_counters.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_events.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_module.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_mmu.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pte_batch.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_tlb_batch.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_push.o: No such file or directory
ldld: cannot find : cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pushbuffer.o/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-frontend.o: : No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_thread_context.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_tracker.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kepler.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kepler_ce.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kepler_host.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kepler_mmu.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_maxwell.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_maxwell_host.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-i2c.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal_ce.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mempool.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal_host.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mmap.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal_mmu.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-p2p.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pat.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta_host.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta_mmu.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vm.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vtophys.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-interface.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_policy.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-mlock.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_utils.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kvmalloc.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pmm_sysmem.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pmm_gpu.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_migrate.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_map_external.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_user_channel.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_hmm.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_heuristics.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_thrashing.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_prefetch.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nvlink_linux.o: No such file or directoryld
: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_test_rng.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_tree_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_allocator_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_mem_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_rm_mem_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_page_tree_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_tracker_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_push_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_channel_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_ce_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_lock_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_utils_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kvmalloc_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pmm_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_events_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_module_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o: No such file or directory
/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nvidia.Kbuild:91: recipe for target ‘/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-interface.o’ failed
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o: make[2]: *** [/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-interface.o] Error 1
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_mmu_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_va_block_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_group_tree_test.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-drv.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-utils.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-crtc.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-encoder.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-connector.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-gem.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-fb.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-modeset.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-prime-fence.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-linux.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-helper.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nv-pci-table.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o: No such file or directory
ld: cannot find /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o: No such file or directory
scripts/Makefile.build:574: recipe for target ‘/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm.o’ failed
make[2]: *** [/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm.o] Error 1
scripts/Makefile.build:574: recipe for target ‘/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm.o’ failed
make[2]: *** [/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm.o] Error 1
/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nvidia-modeset.Kbuild:73: recipe for target ‘/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nv-modeset-interface.o’ failed
make[2]: *** [/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nv-modeset-interface.o] Error 1
make[2]: Target ‘__build’ not remade because of errors.
Makefile:1528: recipe for target ‘module/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel’ failed
make[1]: *** [module/tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel] Error 2
make[1]: Target ‘modules’ not remade because of errors.
Makefile:79: recipe for target ‘modules’ failed
make: *** [modules] Error 2
→ Error.
ERROR: An error occurred while performing the step: “Building kernel modules”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.14.32-rancher2/build" SYSOUT="/lib/modules/4.14.32-rancher2/build"
failed with the following output:
CONFTEST: INIT_WORK
CONFTEST: vmap
CONFTEST: pde_data
CONFTEST: write_cr4
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: sg_table
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: strnstr
CONFTEST: kstrtoull
ld -r -o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-frontend.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-instance.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-acpi.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-chrdev.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-cray.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-dma.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gvi.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-i2c.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mempool.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mmap.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-p2p.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pat.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-procfs.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-usermap.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vm.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vtophys.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-mlock.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-pci.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-registry.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-usermap.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pci-table.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-memdbg.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-report-err.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz18121/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nvlink_linux.o
→ Checking to see whether the nvidia kernel module was successfully built
executing: ‘cd ./kernel; /usr/bin/make -k -j4 NV_KERNEL_MODULES=“nvidia” NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.14.32-rancher2/build” SYSOUT=“/lib/modules/4.14.32-rancher2/build”’…
LD [M] /tm
