Okay so this is weird… I located that logs file and had a look inside. It would be a total waste to send it to you since the entire file is just this over and over
[2021-01-05 06:46:12.107] [info] Checking for update
[2021-01-05 06:46:12.146] [info] Update for version 1.0.38 is not available (latest version: 1.0.38, downgrade is disallowed).
[2021-01-05 06:46:12.146] [debug] No updates. Checking for an update in the next 60 seconds…
[2021-01-05 06:47:12.147] [info] Checking for update
[2021-01-05 06:47:12.195] [info] Update for version 1.0.38 is not available (latest version: 1.0.38, downgrade is disallowed).
[2021-01-05 06:47:12.196] [debug] No updates. Checking for an update in the next 60 seconds…
I can’t imagine anything being out of date since I only installed everything about a week or so ago. This means I downloaded everything on the same day so it is highly unlikely that anything would be out of date. As for admin rights, it is a single user PC… the admin account is the only account on this PC so, definitely have admin rights.
Next up I went to localhost:3080 and took a screenshot of what was there (everything running under Applications, nothing installed under Cache) so I could show you and maybe you could see something was missing…
Next I tried to install Cache once again so that if it DOES make any entry in the logs then it will be at the end and easy to spot when I send you the logs.
…this time Cache installed without any problems. 🤷♂️ I have no explanation for it. The only thing I did differently this time was going to the Connections tab and actually STARTING my connection to localhost before I tried to download and install Cache. That sounds like it might have something to do with it… also, not really. But maybe?
In any event, it is installed now so all is well.
Just in case, I am uploading my logs anyway in the hopes it might prove useful in finding out why this happened and possibly preventing it in future installs.
.nvidia-omniverse.zip (647.5 KB)
