Can't change color of Isaac Asset sektion cabinet
I’m trying to change the color of the Isaac Asset sektion cabinet. When I create an instance from the Nucleus server in the Isaac Sim UI, the mesh and material prims are greyed out.
If I try to adjust the colors of the material, I get a reference to instance proxy error on the screen.
I’ve tried collecting, flattening, bringing in the sektion_cabinet_visual.usd file that is also included in the Isaac Assets library to a local version, but I can’t seem to get anything to allow for the color to be changed. I can delete the top level Xform prim for the material and add a new material, but it also deletes the mesh.
I’m sure it’s something obvious, but I’ve been trying for a while now. Any help is appreciated.
i found the method ,
and can change shader attributes.
Nvidia we need better Documents and better software!!! oh my god!
