I’m developing robot simulation environments using IsaacGym.
I have two questions about object color setting.
It seems that IsaacGym cannot properly retrieve color values defined in URDF file. It is not supported in current version? or, am I missing something?
I want to apply a set of different colors for an object. I mean, for example, there is single cup mesh model in the environment, and I want to set blue color inside, and red outside. Is there any method for it?
It seems that by “set_rigid_body_color()”, just one color is available for each mesh model.
Preview 2 supports URDF materials. For example:
<material name="aluminum">
<color rgba="0.65 0.65 0.65 1"/>
</material>
can be used like this:
<visual>
<geometry>
<cylinder length="0.1133" radius="0.00635"/>
</geometry>
<material name="aluminum"/>
</visual>
Your comment is general method to set a material for URDF.
But in my case, is does not work. I don’t know the exact reason.
Instead, I solved this issue by editing the collada mesh file(.dae) directly using online editor.
After I changed the color of the mesh file(collada) and re-import, it works perfectly !
Thanks for your comment anyway !
