Can't see material and shader properties
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
I’m trying to create a material in Isaac Sim. I start from the initial scene and add a mesh. Next I add a material (OmniPBR) but I can not see the material properties. The “Material and Shader” section is empty and there are no properties I can see or edit. I tried using different meshes and material types but nothing seems to work. Any idea why this can be happening?
Thanks,
Luis.
I’m not able to reproduce this issue on my side. Are there any error or warning messages in your log that might point to the cause? Could you please share your log file and, if possible, provide a screencast demonstrating the issue? This will help us better understand what’s happening and assist you more effectively.
The problem was on my side. I was not using the shaders in the graph editor properly. It works now. Sorry about that.
Best,
Luis.
