I have been using Merge Mesh Tool in Isaac Sim, I have succesfully managed to merge the prims but before or after the merge the material is not displayed properly. What I mean is only the color of the material is reflected after the merge. Is there a way to fix that?
Related topics
| Material not applied correctly to mesh | 2 | 406 | April 5, 2024 | |
| Unable to show material correctly | 0 | 78 | August 14, 2024 | |
| Material Issue in Isaac Sim | 4 | 168 | April 5, 2025 | |
| Replicator's "Projection Material" no longer works in Isaac Sim 4.0.0 (Replicator 1.11.8) | 5 | 443 | August 20, 2024 | |
| Isaac sim 4.0 Robotiq Gripper Asset looks folder and mesh grayed out | 0 | 121 | July 3, 2024 | |
| How to combine visual from a glb and collision mesh into usd file that could be loaded into isaacsim? | 0 | 200 | August 17, 2024 | |
| Merge 2 meshes using Action Graph | 0 | 91 | July 8, 2024 | |
| When loading a USD object, some material displays differently than expected | 1 | 196 | September 20, 2024 | |
| Can't see material and shader properties | 3 | 159 | May 13, 2025 | |
| No color with material | 2 | 195 | August 22, 2024 |
