We have a jetson AGX orin dev kit that we connect to the host PC (ubuntu 22.04) through the provided USB-cable. We set it in recovery mode, but it is still not being recognized as a board in the sdkmanager. Are there any possible solutions to this?
Hi
Based on the past experience, it is most likely
Only the type C port on the opposite of the power jack input could be used for flash. Are you sure you use the correct usb port?
How did you put the board into recovery mode?
There is no other solution. Recovery mode is the essential when flashing board.
we are using the correct USB port, and put the board in recovery mode by holding in the force recovery button, then pressing the power button while still holding the recovery button
Does your host PC “lsusb” command show NVIDIA device after your attempt to enter recover mode?
Are you sure your board was not powered on state when you pressing the power button? If the board is already powered on, then you should press reset button but not power.
