Unable to enter the recovery mode for jetson orin nx 8gb for flashing through sdk
trying to enter into the recovery mode but the board is not getting detected by host machine.
to enter into the recovery mode following steps
  1. Start with the Jetson Orin AGX devkit turned off and disconnected from the power supply.
  2. Get the USB-A to USB cable and connect the USB-A end to your host computer (the computer where you installed Jetpack) and other to nx
  3. Press and hold the FORCE RECOVERY button
  4. While pressing the FORCE RECOVERY button, press and release the RESET button
    5.connect power to the orin nx board and release force recovery mode
    6.in host machine check lsusb
    nvidia crop should be visible but its not visible
    can i get help in the process please
First, I think the point here is you should identify what platform you want to ask first.
Your topic said “Orin nx 8GB” and this topic is filed in Orin NX forum but your topic seems talking about Orin AGX devkit.
Official orin NX carrier board won’t have a “button” to trigger recovery mode. There is only a pin and need to use jumper to trigger…
Thus, I really don’t know what platform you are doing here.
I want to add that the recovery button (or pin on models with pins) operates like a shift key on a keyboard. You would hold it down while either (A) resetting power on a running system, or (B) adding power to an unpowered system, and then letting go of recovery (there is no requirement to hold down the recovery button/pin).
This sequence would be invalid:
  1. Start with an unpowered system.
  2. Hold recovery down, or short pins on the model, depending on whether your model has pins or a button.
  3. Press and release power reset button.
  4. Let go of the recovery button.
  5. Turn on power.
During the illustration of an invalid sequence it would have failed because the power reset button only works if power is already applied, and adding power did not have the recovery button down while powered on. Valid recovery mode implies an already powered system being reset with recovery button held down, or else powering on with the recovery button held down.
Entered in recovery mode but my board is not getting recognized by my system.my system I am using virtual box over windows and in that using sdkm manager.
now my board getting the boot screen and showing the blank screen
VMs tend to fail, they need to be configured to pass through the USB. If USB is passed through, VMs tend to still fail because the USB will drop and reconnect during flash (VMs need even more configuration to make sure the USB reconnects after a disconnect). You’d have to ask the VM people for virtual box how to do that.
